Hondajet
Old 01-29-2008, 05:16 PM
eddienyr
Default Hondajet
anyone build one yet
eddienyr is offline
Old 10-16-2008, 10:31 PM
rampage-1
rampage-1
Default Honda Jet
A freind and I just got two of these to build this winter
Pusher prop 9x7-3blade
2- 900kv 650 watt motors
plane with retracts should weight in a 9 pounds +-
ID:	80844   Click image for larger version
ID:	80845   Click image for larger version
rampage-1 is offline
Old 10-16-2008, 10:53 PM
Wow nice jet, I would like to have the full scale version Have fun with your project, Chellie
Old 10-17-2008, 01:48 AM
The Don
Balsa Butcher
The Don's Avatar
Which motors you planning on may I ask? I picked up one of these kits as well and plan on building it this winter.
Don
The Don is offline
Old 10-17-2008, 04:51 AM
rampage-1
rampage-1
Scorpion 3032-10Specifications
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ........................... 32.0 mm (1.260 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 14
Motor Wind ............................................. 10 Turn Delta
Motor Wire ...................... 24-Strand 0.21mm (31 AWG)
Motor Kv ............................................. 823 RPM / Volt
No-Load Current (Io) ................................. 2.61 Amps
Motor Resistance (Rm) ............................. 0.029 Ohms
Max Continuous Current ............................... 80 Amps
Max Continuous Power .............................. 1200 Watts
Weight ...................................... 222.9 Grams (7.86 oz)
Outside Diameter ......................... 37.50 mm (1.476 in)
Shaft Diameter .............................. 4.97 mm (0.117 in)
Body Length .................................. 49.9 mm (1.964 in)
Overall Shaft Length ....................... 88.5 mm (3.484 in)
Old 10-17-2008, 05:20 AM
The Don
Balsa Butcher
The Don's Avatar
Thanks!
The Don is offline
Old 10-17-2008, 05:37 AM
Figure.N9ne
Figure.N9ne's Avatar
which kit is it?
Figure.N9ne is offline
Old 10-17-2008, 05:39 AM
The Don
Balsa Butcher
The Don's Avatar
They are here. http://www.nitroplanes.com/clitelrcmoai.html
The Don is offline
Page generated in 0.09176 seconds with 18 queries
