Lipo batteries show charge, but nothing happens.
Old 05-17-2021, 04:17 PM
hkeelljr
Default Lipo batteries show charge, but nothing happens.
I decided to finish up plane that I started a few years back, and when I plugged in one of my lipo batteries, nothing. My enter shows that it has a charge, according to the article I just read in the June issue of MODEL AVIATION, the author mentions that they have to be discharged and recharged to come back to usefulness. Or did I read it wrong.Thanks for the help. The meter I have, I purchased from Heads up Hobbies, and it shows the charge as well the level for each cell.
hkeelljr is offline
Old 05-17-2021, 08:40 PM
Information ?
What size battery in mAh .... C rate ..... Cells (voltage) ....
What is meter showing ? Volts / Charge %
LiPo's generally do not revive if left too long in very low discharged or too high charged state ... its literally a death sentence to them. Some peopl report revived LiPo's - but you never hear later how they only had a short life before failing again.
Give us info and we can answer ...........
Old 05-17-2021, 08:50 PM
crxmanpat's Avatar
So what does your meter say when you hook the battery up to it? Not just total voltage, but the voltage for each cell?
What are the specs of your setup in the plane? Motor, ESC, etc.? If the battery has a charge and you are getting nothing from the plane, there may be something wrong with the setup. Does the ESC have a built-in BEC, or is it an Opto type that would require a separate UBEC to supply power to the receiver?
crxmanpat is offline
Old 05-17-2021, 10:34 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Originally Posted by hkeelljr View Post
... when I plugged in one of my lipo batteries, nothing. ...
Have you tried another battery?
Lower cell count is no problem, I just want to make sure the wiring/electronics/setup is still ok.
... The meter I have ...
What meter, make/type/link?
What controller, make/type/link?
... the author mentions that they have to be discharged and recharged to come back to usefulness. ...
Some excellent battery info
LiPo best care practices - post#8346 - RCG
Contents
  • Maximizing Cycle Life and Performance
  • Storage Facts
  • Fun Facts
  • Nerd Facts a.k.a Solid-Electrolyte Interphase (SEI) layer
  • Thermal Runaway
  • Results, Comparisons, and Lies exposed in opening posts
And there's this post#198 by Frank Siegert, about (yet) another advantage of heating a battery to body temperature, through and through, for about one hour. Before using and before charging. Not only voltage is higher and battery wear lower, but also ...
Short flight time is killing me - post#198
The above LiPo best practices post is from this active thread, with more info about C-ratings, discharge rates, stickertuning and other blatant lies. Using uniform tests, getting published/referred in opening posts:
Battery Load Test Comparisons - RCG
Want more background info?
Lithium Polymer Battery Technology - RCG
An introduction, with special consideration of RC model lithium batteries.
By dipl.-ing. Frank Siegert, a.k.a. RCG user bzfrank.
ron_van_sommeren is offline
Old 05-18-2021, 02:22 AM
hkeelljr
Well, folks, I finally figured things out. Unfortunately, I asked a question without sitting back and keep trying. After I plugged everything on to the receiver things started working again. I apologize if I have caused any inconvenience. But it's been several years, a job change, still working in EMS, and other interests. But thanks for all the replies.
hkeelljr is offline
Old 05-18-2021, 10:04 AM
Usual to let us know what was actual problem ... helps others then.
SoCal Perky
13
07-04-2019 12:35 PM
misplacedtexan
10-26-2013 08:48 PM
747
07-06-2012 03:17 PM
Quick Reply: Lipo batteries show charge, but nothing happens.
Page generated in 0.09557 seconds with 12 queries
