First paint job
Old 06-09-2016, 02:13 AM
Vic Z
Default First paint job
After a hundred crashes, I figured it would be fun to paint my Sportsman trainer.
It is mostly made of gorilla glue, and is full of seems and wrinkles, but still a fun flyer and holds a special place for me.
Got a primer coat on, and apparently I'm not a body guy. At least it will all be one color again
Maybe I will slap the 480 and 30 amp esc from the Trojan in it just for fun.
Vic Z is offline
Old 06-09-2016, 02:22 AM
P51 fan
Amazon Airspace Tester
P51 fan's Avatar
No pics??!
P51 fan is offline
Old 06-09-2016, 02:55 AM
Vic Z
No pics of the progress. Will get some up tomorrow.
Here are a couple of the reason for painting though.
Every time I tried to get her upside down she headed for the dirt uncontrolably. Apparently high dihedral wings and a stability system absolutely rebel against such behavior.
File Type: jpg
File Type: jpg
File Type: jpg
Vic Z is offline
Old 06-09-2016, 03:06 AM
She is due. Remember to hold the can at a distance and spray just enough for coverage. 2 light coats are better than a very heavy one. Inverted dihedrals can require a lot of input.
Old 06-09-2016, 05:24 AM
P51 fan
P51 fan's Avatar
lol...one just doesn't say 'paint job' and then not add pics.
There are lots of tricks for fixing up that foam, carefully using a heat gun or iron can pull out seams and wrinkles, hot water is supposed to work also but I have never tried it. When you mention Gorilla glue are you using the original (brown) glue? If so, possibly you already know that if you mix it with water it foams up and makes a great filler/glue combo that is easy to carve and sand.
One more thing, I do hope you are using more than just two rubber bands criss-crossed like in the first pic, if not I would start.
-Bob
P51 fan is offline
Old 06-09-2016, 07:59 AM
Vic Z
One of the fun parts of this project is that I got to go out and buy a detail gun
We like our toys you know.
Yes, gorilla glue works wonders. And the hot water trick works great. We have an insta hot on our sink (great tool for this), and it really does reform dented foam.
The parts that don't look so great are the parts where I used light weight spackling. It just doesn't really sand well.
The last time I flew it, it got windy, but I figured "aw heck, just one more battery". We all know how that ends.
I had read stories about guys getting their planes stuck in a tree thinking what an idiot. But after trying to save a landing blown off course, there I was
Caused allot of scarring between all of the pulling it through branches and poking it with a long pole with a stick duct taped to it. Lol
Any way, she ain't gonna be perfect, but it's all a learning process and good fun.
The most important tool you need for this hobby is a sense of humor.
Vic Z is offline
Old 06-09-2016, 08:17 AM
P51 fan
P51 fan's Avatar
What kind/brand of spackling did you use? I have never had a problem sanding lightweight spackle but I read something about Dap brand spackle being hard to sand. I do know that if it isn't completely dry any lightweight spackle will not sand. If it looks dry and feels dry but is cold...it isn't dry.
-Bob
P51 fan is offline
Old 06-09-2016, 04:32 PM
Porcia83
meh...some bondo and duct tape, good as new!
I like the Testors Short cut paint for the foam, works great. Liquitex works good too.
I'm a recent convert to Foamtac glue for most anything foam now. dries clear, dries pretty quick too, and most importantly isn't brittle like CA and expoxy. I'm also using their filler too...looks like drywall compound. dries fast, and all white. Easy to sand as well. I took a totally crushed Durafly Skymule and pieced it back together, then skim coated it and it came out great.
As for the inverted flight....max out that elevator throw, and start your trick about 5 mistakes high!
Have fun.....
Porcia83 is offline
Old 06-09-2016, 06:32 PM
Vic Z
Well here she is. Primed up and all ready for color.
Not sure how it will turn out, but I bet it ain't her last time in the paint shop
I'm sure I'm doing it all wrong, but it's just for fun.
The spots where the skin of the foam is missing doesn't like to take paint.
That's ok. I'm in this to fly, not to show.
Plus like the old man at the LHS says "it's just a foamy".
File Type: jpg
File Type: jpg
Vic Z is offline
Old 06-09-2016, 08:27 PM
Vic Z
Here it is with some color.
Looks better that I expected.
Good from far, far from good.
Will look really good 100' up in the air.
File Type: jpg
Vic Z is offline
Old 06-09-2016, 08:34 PM
P51 fan
P51 fan's Avatar
Lookin' good...now some flames...
P51 fan is offline
Old 06-09-2016, 08:46 PM
Vic Z
I thought about it. Would be very ironic.
Doing a blue cowl with a couple of scallops, and probably blue landing gear with wheel pants.
Vic Z is offline
Old 06-10-2016, 05:55 AM
P51 fan
P51 fan's Avatar
That should look good.
So, not trying to be a spackle queen here, but it has been bugging me that you are having trouble sanding spackle. I haven't used it in a while but i used to all the time on foam airframes...literally caking it on the whole airframe then sanding it off to make a smooth surface, then paint or use covering material.
The trick I forgot is I mixed the spackle with water to make a paste, it sticks to the foam much better than plain spackle that is too dry to stick decent, then when dry it sands easily.
I understand you aren't too worried about it here and I'm not trying to pound my spackle tricks, just thought it was a good place to mention the water trick in case you decide to try again.
Here are some spackled foam planes I have refinished.
-Bob
File Type: jpg
File Type: jpg
File Type: jpg
P51 fan is offline
Old 06-10-2016, 06:40 AM
Vic Z
Nice work P51.
All input is much appreciated. I am here to learn, and some day hope to help others.
I used Dap, and someone said that it is known to not sand well. Just tries to roll out. I will try the water trick next chance i get.
How do you cut those lines in without peeling the base color up with tape?
Vic Z is offline
Old 06-10-2016, 07:02 AM
P51 fan
P51 fan's Avatar
Thanks. Dap is the brand I heard is absolutely horrible to use, the Patch-n-Paint is junk I guess...at least for what we are trying to do. I have never used it.
I appreciate that you understand I'm just trying to show some success I have had using spackle and what you can do. All of these planes are rebuilt from crashed garbage, when my LHS was still open they would save me the carcasses of crashed planes to fix up.
I mix the water and spackle right in the tub, literally to the point that it will run and drip off the model. If it is too runny just let the tub sit a while with the cover off and mix it up again...water evaporates off and it gets thicker, after you are done using what you need put the cover on the tub and the spackle will dry out back to normal and be ready for next time. I have spackle here that I have used several times over the years that is still good to use. Let it dry completely on the model then sand away, all the little foam beads, cracks, seams, wrinkles fill and even out smooth.
I don't cut the lines, the Spitfire and Corsair are hand-painted with Apple Barrel paints...the Spit is then sprayed with clear gloss, I never did spray the Corsair. I didn't tape anything. The Formosa and Formosa II are covered with Solite film...just like a balsa plane is covered.
I can't say it enough but if the spackle is not completely dry it will roll out, I mentioned already but if it is cold to the touch it still isn't dry, the cold feel is caused by evaporation. Once the excess water evaporates out you are left with a very nice ready to sand spackle job.
-Bob
P51 fan is offline
Old 06-10-2016, 01:01 PM
Porcia83
This is the stuff I use and as P-51 noted, add water to thin it out. First time I tried I applied with a Popsicle stick and realized that wasn't going to work too well.
File Type: jpg
Porcia83 is offline
Old 06-10-2016, 02:02 PM
P51 fan
P51 fan's Avatar
I will have to see if I can find some of that, I bet it is better than plain old lightweight spackle/filler.
Btw, to keep tape from peeling up your base color use blue painters tape, but before you apply it stick it to your t-shirt or pants to take some of the "sticky" off of it. It will still stick well enough to mask but won't stick TOO well.
P51 fan is offline
Old 06-10-2016, 07:38 PM
Looks great Vic!
Old 06-10-2016, 09:57 PM
Porcia83
PM me your address, I'll shoot you over a tub of it. Probably 80% of it is still there, good as new. I have two more in storage just in case. I know I know...what does that say about my confidence!
Porcia83 is offline
Old 06-11-2016, 07:26 PM
Vic Z
I'm thinking this might actually turn out ok for a first timer.
Don't remember where i learned it, but "post its" work well for masking. They don't take off any paint. Bleeds a little, but it isn't hard to cut back in with a small flat brush.
I didn't realize that I would, but I am actually enjoying this.
File Type: jpg
File Type: jpg
Vic Z is offline
Old 06-12-2016, 05:13 AM
P51 fan
P51 fan's Avatar
That is looking great Vic! Those colors should look nice in the air too. Nice job and good tip about the "post its".
Thanks! I'll drop you a pm.
P51 fan is offline
Old 06-12-2016, 06:47 AM
TommyC.
Vic, What type of paint did you use? Looks Awesome!
TommyC. is offline
Old 06-12-2016, 06:58 AM
P51 fan
P51 fan's Avatar
Looking at those pics...and the water in the background...I think a set of floats are needed...
P51 fan is offline
Old 06-12-2016, 03:09 PM
fdnyjery
FDNYJERY
fdnyjery's Avatar
P51 fan you speak of mixing light wait spackle with water. What is your ratio of water and light weight spackle ,in your mix ?? Many thanks fdnyjery aka Jerry
fdnyjery is offline
Old 06-12-2016, 03:11 PM
Vic Z
Thank you.
I think i will make the scallops bigger and do the rudder blue to give it more pop.
I use Behr Marquis sample size from home depot.
Goes on great, sticks as well as can be expected, and they can mix up any color you want, and even match a color for you. @ $5 for a 6oz jar, which is really allot.
Vic Z is offline
Quick Reply: First paint job
Page generated in 0.14269 seconds with 26 queries
