Minor crash Super Cub S (Hobby Zone)
Old 07-29-2014, 03:30 AM
RVDriver
RVDriver (New Member)
Question Minor crash Super Cub S (Hobby Zone)
OK I "Cracked the Cowl" BUT :
How do I get the prop spinner off ?
Need to remove prop and then remove Cowl and Glue from the inside, think I will rough up then try JB Quick Weld.
I have pulled just about flipped the Spinner inside out, the manual says to replace motor remove spinner, remove prop remove cowl etc, But HOW??
RVDriver is offline
Old 07-29-2014, 03:59 PM
flydiver
flydiver's Avatar
Peel back the 'wings' around the prop and unscrew. That's it. Some are glued. OK to use force.
Small strips of well placed packing or strapping tape will work better and be WAY faster than JB Weld.
Check the shaft for being bent, motor mounts, firewall, etc.
Yes, the motor IS supposed to be pointing to the left and down slightly. You didn't do that.
flydiver is offline
Old 07-29-2014, 06:21 PM
RVDriver
Thanks will try this afternoon
Yes, the motor IS supposed to be pointing to the left and down slightly. You didn't do that.[/QUOTE]
RVDriver is offline
Old 07-29-2014, 06:53 PM
Theplumber
down and to the left as you face the nose of the plane? rite? (Just wanting to know for myself, as if you were sitting in the cockpit i thought it was down and to the right, so if you were in front of the plane it would be down and to the left.)
Theplumber is offline
Old 07-29-2014, 07:56 PM
Down and to the right, from the 'pilots' point of view.
Old 07-29-2014, 08:11 PM
Theplumber
Thanks (Obviously i'm new )
Old 07-30-2014, 12:05 AM
RVDriver
ok
i asked the "original question" Never thought of it till now
When you said its "OK to use Force" Right or left handed thread looking from the front of plane ?
Thanks again !
RVDriver is offline
Old 07-30-2014, 03:23 AM
RVDriver
Default Thanks guys Everything under control
Many thanks to everyone almost done with repairs and starting new Paint
RVDriver is offline
Old 07-30-2014, 09:20 PM
flydiver
flydiver's Avatar
Be easy with the paint, especially the back. Guys that do a total paint job are often surprised to find out they screwed up the center of gravity and now need more repairs after the post-fix flight.
flydiver is offline
Old 07-31-2014, 02:38 AM
RVDriver
Default Thanks
(y) Thanks Was going yo paint before crash,(crash was very minor) just 2 small cracks in the cowl
But now I will be sure yo check "cg" after Painting
Thanks again
RVDriver is offline
Old 02-08-2015, 02:27 AM
fishycomics
Tip:
masking tape inside cowl, to enforce the strength.
some can make their own cowl out of a recycle bottle and a mold of the cowl.
FISH
fishycomics is offline
Old 02-09-2015, 06:29 PM
cj2563
Newbie Pilot
The lp is the same way it took me forever to learn how to get the spinner off.
cj2563 is offline
Old 02-09-2015, 08:23 PM
fishycomics
Agree the spinner once off, stayed off. if not back on right, for me it wobbled. or am I thinking of the champ.
Old 03-23-2015, 05:45 AM
cj2563
Newbie Pilot
I haven't had that problem
cj2563 is offline
danauti1
09-14-2014 07:19 PM
RVDriver
04-28-2014 09:51 AM
BSWAN
08-18-2013 03:41 PM
simibill
05-22-2012 06:17 PM
Kyonic
07-05-2011 01:38 AM
Quick Reply: Minor crash Super Cub S (Hobby Zone)
Page generated in 0.11935 seconds with 13 queries
