Show off your sweet helis
Old 08-15-2008, 11:14 PM
  #201
theecoop
theecoop's Avatar
Looks very salvagable to me
theecoop is offline
Old 08-15-2008, 11:19 PM
  #202
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
I lol'd when it happened. After a few choice words of course.
Minus the blades it was $70. And since everything is packed in pairs it was really $35 and I have extras.
Blades are subjective because you can use $20 china or $80 italian.
Maybe not 25 deg....but these shafts are no joke....pretty good bend.
SkunkyMagoo is offline
Old 08-15-2008, 11:58 PM
  #203
GANJAR
GANJAR's Avatar
Yah thats not too bad of a bend right there lol. What else cost 70 bucks? How much are 500 main shafts as opposed to 8 to 9 dollar a pack 450 shafts?
GANJAR is offline
Old 08-16-2008, 12:01 AM
  #204
SkunkyMagoo
Newborn Rotorhead
A set of mainshafts is $10.99.
But looking at the pic...quite a few things other than a shaft needed to be replaced
Old 08-16-2008, 12:05 AM
  #205
GANJAR
GANJAR's Avatar
Ah yah, i just saw it 10 seconds ago lol. Man thats a good crash right there. At least your tail boom is ok it looks like.
GANJAR is offline
Old 08-16-2008, 12:06 AM
  #206
SkunkyMagoo
Newborn Rotorhead
Nope that is bent worse than the shaft lol.
Old 08-16-2008, 03:06 AM
  #207
GANJAR
GANJAR's Avatar
Wow lol, now thats a crash. I almost had one last night, i was such in a rush to fly my heli with the last 20 minutes of sunlight left i forgot to attach 2 outta 3 of my ball links to my swash plate from the servos lol. Only the elevator was attached, I guess the spinning of the blades leveled it out cause it lifted in the air about 7 feet, suddently had a surge of power i dont know, then sparks flews and my battery came falling to the ground seperate, but at the same time my heli came down lol. Something struck my balancer cord from my battery and the wires touched causing alot of sparks. I checked it over and my autorotation and main gear are rubbing , my swashplat was only 1/3 on and my batteries cables were stripped and open.
So i got mad thinking i fried my 95$ battery, Flight Power EVO 25C 2500 MAH and hucked it on the ground, it sparked again. Then i was like , well maybe it's ok, so i put electrical tape on the ends and tried charging it. It seemed ok and charged like i think it should have. I checked today and no puffing yet, but i don't have a cord to balance it anymore. Can i buy one someehwere u guys know?
GANJAR is offline
Old 08-16-2008, 04:17 AM
  #208
jasmine2501
Custom User Title
jasmine2501's Avatar
Laughing off our crashes and moving on is part of the hobby but I see a few life-threatening situations in that story. I would be pretty freaked out.
"GunnyGlow" told me this and I live by it - he found a broken linkage on his trex-600 in the pre-flight check - I had just watched him fly it earlier that day and nothing was wrong and it was a perfect landing.
Your heli exploded at 7 feet of altitude were you wearing a helmet?
You gotta make sure you check over your whole heli before every flight. Make sure all the wires are tied down with zip ties and away from moving parts. Since you are using tri-flow before each flight, while you do that, check the ball links from the servos up to the head, always in the same order - tail too. Wiggle things around and check for any odd play, binding, or rubbing in the head or swash plate and make sure the flybar and blades move smoothly. Use the velcro strap on the battery so it can't separate from the helicopter and its wires can not reach any moving parts (wires down and front). Use the throttle hold switch, by habit, when plugging in. Check to be sure the gyro initialized correctly and spool it up slowly. Watch for any odd vibrations and listen for any changes in the sound - if you notice anything just cut it and don't fly till you figure out what it is.
You can get new balancing plugs - you should take the battery to Colpar and see if they can help you. It might not be safe to use.
jasmine2501 is offline
Old 08-16-2008, 08:06 AM
  #209
GANJAR
GANJAR's Avatar
Yah that experience made me realize i really need to be more careful and i was quite angry at myself for doing it. Helis are jsut so fun to fly though and with the sun goin down quicker now as winter approaches, so does my flighttime.
GANJAR is offline
Old 09-11-2008, 10:07 PM
  #210
MaxAdventure
AMA 198798
MaxAdventure's Avatar
Default looking for something bigger?
here are a couple of conversions I did.
ID:	77821   Click image for larger version
MaxAdventure is offline
Old 09-12-2008, 03:27 AM
  #211
jasmine2501
Custom User Title
Yeah I'm looking for something bigger... like maybe a bigger photo of your conversion? Or maybe just tell us what you did?
Old 09-13-2008, 01:01 AM
  #212
Old Sloppy
Old Sloppy's Avatar
I must be lost here.
I see pix of "conversions" but I can't tell just what was converted...
Please explain exactly what was converted.....
Harry
Old Sloppy is offline
Old 09-13-2008, 01:02 AM
  #213
MaxAdventure
AMA 198798
I was looking for an electric larger than a 325 size machine. I didn't feel like spending what it takes for a Mikado, or an Ion X, etc. decided I could do a lot better than align at a 600. I had a nitro Pantera 50 and I liked the heli a lot, so I tossed in a motor. Conversion went really well and while the photos show some massive 6Ah batteries, I can get over 10 minutes on them. With some smaller 5Ah cells, it ended up the same weight at the nitro machine with fuel.
Old 09-13-2008, 10:01 PM
  #214
jasmine2501
Custom User Title
Oh cool... dude - check this:
http://www.rcgroups.com/forums/showthread.php?t=919545
Come on out if you can!
Old 09-17-2008, 03:32 AM
  #215
Dwntyme
Addicted to R/C's
Dwntyme's Avatar
My 2 TREX's 600N pro and 450sa
Bad camera top half is bright orange.
Dwntyme is offline
Old 09-18-2008, 05:05 AM
  #216
Old Sloppy
Old Sloppy's Avatar
Orange/Pink what's the difference?
Harry
Old 09-19-2008, 01:06 AM
  #217
Dwntyme
Addicted to R/C's
Dwntyme's Avatar
Hahahaha difference is as stated "Orange and Pink" hummmm LOL
Dwntyme is offline
Old 10-11-2008, 08:30 PM
  #218
RossFW
Raptor E 550 with TT and Quick UK upgrades.
Spent so much on it, I'm afraid to do anything except Hover and slow circuits!! (But it looks nice)
RossFW is offline
Old 10-11-2008, 08:58 PM
  #219
jasmine2501
Custom User Title
Sweet 550! Did you get the red metal parts that way or color them somehow?
My Blade 400 is now "monochrome" so I'd love it if I could find some black or white metal parts... but they are only in blue... unless I want off-brand parts.
Old 10-11-2008, 09:25 PM
  #220
RossFW
The CNC parts come that way from Quick UK. They have up-grades in a few different colours for most popular Helis, so you could probably get what you wanted from them.
www.quickuk.eu
RossFW is offline
Old 10-12-2008, 12:40 AM
  #221
SkunkyMagoo
Newborn Rotorhead
You can get the grey/black cnc parts from Align.
Old 10-15-2008, 04:35 AM
  #222
Dwntyme
Addicted to R/C's
Dwntyme's Avatar
My first inverted tail in funnel...
Dwntyme is offline
Old 10-21-2008, 04:38 AM
  #223
KE4NYV
KE4NYV's Avatar
I took these for another board, I'll post them here too:
My mCX is missing, but everyone knows what those look like by now.
KE4NYV is offline
Old 11-25-2008, 11:10 AM
  #224
caltrop
Can't Help Myself
caltrop's Avatar
Build Review E-flite Blade 400
My Blade 400 with a Venom Noze canopy. Yes, a TREX 450 canopy fits the Blade 400; it's a little tighter in width but it works. The Noze canopies come without holes or grommets and come in blue, orange, & green; you can get them on eBay, Tower Hobbies, or direct from Venom. I also went with the E-flite blue tail to match the canopy.
There's the little mCx here as well. It needs a new flybar.
I added brite yellow trim sheet strips to the tail boom to aid visibility.
Here's how to make the mCx faster, which is why I need a new flybar. It starts getting hard to turn when it get going real fast or the battery is getting low especially in left turns.
http://www.wattflyer.com/forums/show...3&postcount=46
caltrop is offline
Old 01-12-2009, 05:32 AM
  #225
johnnycat500
Here's my Trex 450
Name:	DSC_4693 - 2000x1328.jpg
johnnycat500 is offline
Quick Reply: Show off your sweet helis
Page generated in 0.13783 seconds with 16 queries
