Tractor prop Vulcan
Old 03-27-2021, 10:18 AM
Default Tractor prop Vulcan
This image has been resized. Click this bar to view the full image. The original image is sized 4000x3000.
Here's the Tractor Prop version I put together ... just deciding whether to print controls again as the skins are very thin ....
She has no servos in at present but all else is there ... ESC / Motor / Rx etc.
AUW to fly is 1225gr .... thrust was measured at over 1kg ..... so no problems to fly ... be a bit fast though ... and landings will be 'greasers' !! Wheels are fully removable - they just unclip.
Old 03-27-2021, 11:34 AM
Super looking Vulcan. Hoping it flies as good as it looks.
Old 03-27-2021, 12:50 PM
Very nice.
A tractor Vulcan does have some advantages particularly if undercarriage is used as it allows a scale 'high alpha' landing, just like the full size did!
Old 03-27-2021, 05:58 PM
Some have probably been following the RCG thread on this 3D print Vulcan. Basically 1m span ... 900 - 1000gr AUW, 50mm EDF ... and proper ducting to 4 outlets for thrust.
The builders migrated to talking about a Pusher version ... which a couple have built. Having already gone through the Pusher on a Vulcan before .... I remembered the cons outweighed the pros. So I started looking at tractor ... spinner to give a reasonable nose profile once prop is spinning etc.
As you say Q .... this allows me to high alpha that landing .... and despite that prop seen on the ground - the in-flight look should still be good.
I was hoping to modify the elevon set-up from the 4 servo split design ... but got fed up playing with Mesh programs to fix it ...
Have to decide what colour scheme to apply now ...
Old 03-28-2021, 04:03 PM
pmullen503
How's the balance? Where will the batteries have to go?
pmullen503 is offline
Old 03-29-2021, 04:53 PM
Battery will go where the EDF was - on the CoG mid of fuz. If you look at the photos above - you can see the EDF top hatch.
I haven't balanced her yet - just did beam calcs to see approx where weights go.
Will have pics shortly.
Old 03-29-2021, 05:44 PM
Here she waiting paint to harden (its touch dry) .... get her servos and then CoG setup. Prop removed while I painted spinner to blend in.
Here is the Vulcan 3D hangar so far ....
Taking them from top left = Prop job on wheels, top right is LW-PLA with 50mm EDF / 5000kv + 4S setup, bottom centre is PLA with 50mm FMS and 3S ....
Warbird Electrics
12-27-2020 10:04 PM
64
08-17-2019 12:16 PM
ditchit
08-28-2017 06:25 PM
Delta & Flying Wings
07-22-2015 08:00 AM
ggunners
Flight Simulators
01-19-2012 11:31 PM
Quick Reply: Tractor prop Vulcan
Page generated in 0.08415 seconds with 11 queries
