help SPEKTRUM DX7
Old 08-22-2011, 01:24 AM
Fulanito_uk
Default help SPEKTRUM DX7
Hi all,
Having problem with my DX7,
Turning it on i get no display, however i do hear a beep and the BIND/RANGE test at the back is flashing green....
Any ideas what it could be i'm guessing due to the beep and flashing light at the rear its not the fuse right?
(PS due to my location I think i need to somehow fix this my self as shipping to USA will be pretty hard, im in Chile and the post sucks just moved here and my electrical instruments are very very limited)
THANK you so much for you help
Fulanito_uk is offline
Old 08-22-2011, 01:31 AM
NJSwede
3D wannabe
NJSwede's Avatar
Originally Posted by Fulanito_uk View Post
Hi all,
Doesn't sound like the fuse, but I'd open it up and check anyway just to be sure. It takes about 2 minutes...
NJSwede is offline
Old 08-22-2011, 01:41 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Ok, this may be a stupid question, but have you charged it fully?
Grasshopper is offline
Old 08-22-2011, 01:44 AM
Fulanito_uk
Thanks for the reply... well it worked fine when it got here (low power warning) I had it sent over here from UK where i was living however i think i got sent the wrong charger so pluged it in for 5 minutes and then remembered that the Spektrum uses a diffrent sort of charger so quickly unpluged it... turned it on and had the problem above, makes a beep and the light flashes on the rear...
the charger that was sent to me is a Amerang i think i used it on my old hitec TX, it will not be fully charged but should have enough juice to turn on.....
Old 08-22-2011, 01:53 AM
H'mmm
I've done that with my DX7. If you pull the back cover off, you will find a small metric fuse located in the lower half of the main circuit board. Hopefully all that is wrong is this fuse is blown. Not certain of its value, might be around one ampere or so.
Good luck!
Hitec and JR/Spektrum have opposite neg/pos leads on the charger. If you used one that is for Hitec then you could have problems. Hopefully it's just the fuse. easy fix as i did that on mine. Mine didn't light up the bind button or beep though, it was completely dead.
Old 08-22-2011, 01:56 AM
Grasshopper
If I remember correctly, the charger for the DX7 is the same as the JR charger and the negative terminal is in the center with the positive on the outside of the plug. It's reversed from others.
I use a JR charger on mine. It states the output at 11.6V 50mA.
Old 08-22-2011, 01:57 AM
Fulanito_uk
I hope its the fuse... what worries me is the light and the beep i hope its not a bigger problem
Old 08-22-2011, 01:58 AM
Grasshopper
Too slow again I see. When the fuse blew on my DX7, everything was dead as Bill stated.
Old 08-22-2011, 01:59 AM
Fulanito_uk
i pluged it in to this one
http://alshobbies.com/shop/lookupstock.php?pc=34752
Old 08-22-2011, 02:00 AM
yeah... that's the wrong one.
Old 08-22-2011, 02:02 AM
Fulanito_uk
so should just be the fuse right (fingers crossed)
Old 08-22-2011, 02:14 AM
Only one way to find out, take the back off and check. It's very easy to see and get too. You'll know it as soon as you take the back off.
Old 08-22-2011, 02:16 AM
Fulanito_uk
need to buy a better screwdriver tomorrow... what does a burnt fuse look like?
Old 08-22-2011, 02:21 AM
it's a clear glass tube with metal ends and a wire running through it. If it's blown the wire will be burned in two.
Old 08-22-2011, 02:24 AM
Fulanito_uk
well i will be back tomorrow... THANKS EVERY ONE FOR YOUR HELP!!
(so angry at myself... walking to the corner in shame)
Old 08-22-2011, 02:25 AM
Grasshopper
If it's blown, it will look like this.
Old 08-22-2011, 02:34 AM
If you have access to a digital multimeter, turn of your transmitter, set the meter to the resistance X1 range and short the two meter leads together. The meter should show zero ohms, or very close to it.
Then touch the meters probes to each side of that fuse. Again, the meter should show zero ohms or very close to it. If not, its blown.
Old 08-22-2011, 02:35 AM
Fulanito_uk
i hope i see that tomorrow!
Kyle left all my stuff like that behind so dont have a multimeter (not even a good screwdriver)...
However if the fuse is blow i should'nt hearing any beeps i'm guessing....thats what will keep me up tonight...
Old 08-22-2011, 02:38 AM
Or, set your multimeter to a 20 Volt DC range, turn on your transmitter, and check the voltage across that fuse. It should be zero. If it shows 9 volts or battery voltage, again that fuse is blown.
Old 08-22-2011, 02:48 AM
Fulanito_uk
However if the fuse is blow i should'nt hearing any beeps or getting a green flashing light i'm guessing.... i hope i haven't blown anything else
Old 08-22-2011, 10:06 PM
Fulanito_uk
Ok Fuse is ok... looks like blow somthing in the control, i think i'm cursed....
I'm thinking it might be cheaper just to buy a DX6 a throw this one in the bin due to me being in Chile the shipping charges repair cost etc... waiting in time will be a pain in the you know what!!!
And i guess the DX6 should work on the radien pro.
Philx
01-29-2013 09:51 PM
PhantomSC
07-05-2011 06:56 PM
12
05-06-2011 09:42 PM
grumman5277
03-09-2011 01:35 AM
TSky28
02-08-2011 11:22 PM
Quick Reply: help SPEKTRUM DX7
Page generated in 0.13838 seconds with 17 queries
