Other 2,000 KV motors.
Old 10-28-2008, 01:32 PM
cyclops2
Default Other 2,000 KV motors.
I finally tested my new B P Hobbies A2212-6 motor. 2,000 KV.
Ran good . Horrible vibration. Shook a 4# machinists vise easily. Turns over with either the Worlds strongest magnets or a pressed too tight bearing. NO end play.
Any other $ 20 ..6 turn..2000 Kv motors. USA retailer only ?
I need low voltage, higher amps. due to my B & D VPX cells.
Thanks, Rich.
cyclops2 is offline
Old 10-28-2008, 02:40 PM
Dr Kiwi
Did it vibrate at no-load? Are you sure the prop was balanced? If it is indeed a bad motor send it back to BP for replacement.
Dr Kiwi is offline
Old 10-29-2008, 05:12 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
If you were using a prop saver that could be the problem also. Prop savers dont work well at hi rpm or much over 75-100 watts max.
Larry3215 is offline
Old 10-29-2008, 01:21 PM
cyclops2
It was doing it on 6 volts and no prop. Just the 10 x 10 mm stick mount in the 4# vise. Greg @ BP said it sounds like the 1 or 2 baddies that do happen. GWS motor runs smooth in the same setup.
It is going back for replacement.
cyclops2 is offline
07-13-2008 04:54 AM
alienx
Brushless Motor Construction
41
07-07-2008 03:54 PM
05-14-2008 03:30 AM
admin
WattFlyer Site News, Announcements, Upgrades
12
04-30-2008 03:22 AM
admin
04-17-2006 05:54 AM
000 , 2 , kv , motors
Quick Reply: Other 2,000 KV motors.
Page generated in 0.10146 seconds with 13 queries
