Single EDF nano FPV platform with Thrust Vectoring
Old 06-28-2015, 03:45 PM
VAALLEON
MONOPHAN
VAALLEON's Avatar
Default Single EDF nano FPV platform with Thrust Vectoring
Mono-Phan Triport is built to be the world’s first single EDF nano FPV platform.
It features a brand new 3 way split thrust vectoring system. The new system reduces the servo count to 3, along with weight and consumption. It proved to be a very easy to build and maintain thrust vectoring system.
It is constructed around a 55mm, low amp EDF and has a new 120 degree configuration of the classic longitudinal MonoPhan wings.
Believe it or not, below video is the first outside test! Even though it’s tiny, it flew perfectly from the first indoor flight to the first outdoor flight.
I installed a 5.8G nano Boscam DVR system on it. I am guessing that the flight time will be around 6 minutes. I will post some aerial videos when I have a chance to test more…
Thanks,
https://www.youtube.com/watch?v=IXXNMb065Ag
ID:	181151   Click image for larger version
ID:	181152   Click image for larger version
ID:	181153   Click image for larger version
VAALLEON is offline
Old 06-29-2015, 04:15 AM
VAALLEON
MONOPHAN
VAALLEON's Avatar
A better flight video with the camera on it. Next video will be an aerial one
https://www.youtube.com/watch?v=7E0XVNPfr7U
VAALLEON is offline
Old 06-29-2015, 05:04 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Thats pretty cool!
What controller board are you using? Is it running the stock software or did you program something custom?
I cant tell from the pics how your doing the thrust vectoring. Can you post some more pics of how its setup?
Larry3215 is offline
Old 06-29-2015, 05:50 AM
VAALLEON
MONOPHAN
VAALLEON's Avatar
Thank you Larry3215! I am using a multiwii board. The vectoring system consists of 3 direct driven U shaped aluminum nozzles. I will post more pictures when I have a chance.
The code was being revised since the beginning of MonoPhan project. I have multiple different versions for different thrust vectoring designs. For this particular design, I made a revision on the mixing ratios to make it able for a 120 degree three servo thrust vectoring design to be able to compensate for all four directions.
VAALLEON is offline
Old 06-29-2015, 08:00 AM
Another fascinating project.
Old 06-30-2015, 01:33 AM
VAALLEON
MONOPHAN
VAALLEON's Avatar
Thank you very much mclarkson! Hoping to post some aerial videos soon
VAALLEON is offline
Old 06-30-2015, 02:51 AM
This absolutely blows my mind that you have achieved so much without a computer radio. Bravo sir. Very nice.
Old 06-30-2015, 02:57 AM
Larry3215
Larry3215's Avatar
You dont really need a computer radio to fly most quads. The controller board - multi-wii in this case - does all the heavy lifting.
Old 06-30-2015, 03:36 AM
VAALLEON
MONOPHAN
VAALLEON's Avatar
Thank you Sir! Appreciate the comment
Yes, multiwii is amazing in many ways. The flexibility that it provides via changing the code, the angle/horizon, etc... are great. The disadvantages are on the hardware side. It is really hard to use with servos, probably because it was designed to drive multicopter ESCs rather than servos. Sometimes I really miss those indestructible heli controllers that work in every condition, with a wide variety of input voltages.
Multiwii still wins though!
My TX is a very simple and reliable 6ch radio. It doesn't even do mixing. I like it this way because I like the unit have all the capabilities rather than the radio.
VAALLEON is offline
Old 07-03-2015, 10:37 PM
VAALLEON
MONOPHAN
VAALLEON's Avatar
This is the first aerial video test that I did when I could find a couple of minutes today.
The video is recorded by the little Boscam dvr on my TX. I need to play with the dvr a little bit for better colors.
https://www.youtube.com/watch?v=_CSR...ature=youtu.be
VAALLEON is offline
Old 07-04-2015, 04:16 AM
VAALLEON
MONOPHAN
VAALLEON's Avatar
Here's a better aerial video that I took later in the day. Too windy though! So, didn't take it too high...
https://www.youtube.com/watch?v=zAgln7aA3Rw
VAALLEON is offline
VAALLEON
08-20-2014 08:47 PM
Joe 1320
Electric Ducted Fan Jets
06-03-2013 02:53 PM
Joe 1320
13
02-02-2012 01:15 PM
earthsciteach
10-06-2011 11:03 AM
Quick Reply: Single EDF nano FPV platform with Thrust Vectoring
Page generated in 0.09569 seconds with 18 queries
