FMS fox glider info wanted
Old 03-03-2012, 07:17 PM
themagician
Default FMS fox glider info wanted
i have a fms fox glider with standard motor esc etc,it seems really under powered for its weight and size.
is there a replacement larger/power size motor that would go straight into it without any alterations to the body.
cheers in advance.
themagician is offline
Old 03-03-2012, 08:40 PM
TM4197
Dope&Fabric
TM4197's Avatar
Was the motor mounted by factory? If so, is the motor REALLY secure to the motor mount?
TM4197 is offline
Old 03-03-2012, 08:54 PM
TM4197
Dope&Fabric
TM4197's Avatar
The reason I asked this, some I have seen with the motor installed, which I believe is a 750KV, were loose. This motor should give you plenty of power to do Neg and Pos loops. Also, it should do rolls easily. Make sure it came with at least a 30a ESC. This bird has won some interesting titles for an out of the box bird. Its not a hotiner by any means, but a good thermal ship for its design and a very good slope soarer! I wish I knew the real answer to your question...but the factory motor should be plenty of motor for this one. Then, you might have just got a lemon! It happens.
TM4197 is offline
Old 03-04-2012, 05:14 PM
themagician
Default fox glider
yes factory fitted,just seems like its got no real power to it.just changed the bearings just in case they were tight.
the motor is a 950kv.
Old 03-04-2012, 08:07 PM
TM4197
Dope&Fabric
TM4197's Avatar
...wow if your changing bearings in a motor, your way ahead of me. I would imagine since you have yanked it out with no problems..you can see now what might be able to replace it. I bet Headsup Rc has a motor for ya!!
TM4197 is offline
Old 03-08-2012, 09:39 AM
themagician
Default fox
bearing change very easy about 30 seconds in all to do the 2.
motor seems very poor against such things as a multiplex cularis etc.
03-03-2018 06:18 AM
rcpilot
06-22-2011 04:00 AM
Quick Reply: FMS fox glider info wanted
Page generated in 0.07200 seconds with 13 queries
