Get what you pay for??
Old 07-11-2007, 05:47 AM
Mike Freas
Default Get what you pay for??
I have a new Dynam 70A ESC that I replaced my Jeti 70 with.
Tonight I soldered the connectors on, checked I did it right and plugged her into my STM.
After running at half throttle for about 20 seconds (ESC hanging in the prop wash) it was hot to the touch. I decided to clamp my Amp meter on to check things but I know what the setup pulled already. With a cold half charged lipo I was pulling 41 amps at WOT. After a 30 second run blowing all kinds of stuff around the garage the ESC was HOT:
Mike Freas is offline
Old 07-11-2007, 06:08 AM
Rabbitcreekok
Rabbitcreekok's Avatar
My wild guess would be the thinner one is the Dynam. The Jeti probably has some heatsinks which help it to run cooler, hence it is thicker.
Rabbitcreekok is offline
Old 07-18-2007, 10:33 PM
pbunn
Not a heatsink - better fets - lower "on" resistance - less heat
pbunn is offline
Old 07-18-2007, 11:03 PM
Mike Freas
I should have replied to this sooner. I flew this controller on my STM pulling 58 amps at WOT. I expected it to get hot and cut off and sure enough it did several times in flight even after crusing around at less then half throttle.
I think I'm just going to suck up the cost and stick with Jeti or CC. My Jeti controller doesn't even get warm when it's installed on the STM.
yank51
Humor
09-23-2008 08:20 PM
Chad
Australia
08-26-2008 02:37 PM
Humor
08-17-2008 04:37 AM
Tinman
iTrader talk
07-10-2007 11:50 PM
max-nix
Humor
8
01-25-2007 04:00 AM
Quick Reply: Get what you pay for??
Page generated in 0.06787 seconds with 15 queries
