EDF and Pusher Jet Builder's Support
Old 04-15-2016, 04:55 PM
jibwalker
It is the area of the EDF minus the area of the hub not the diameters.
In your case the area of the EDF is
Pi x 27 x 27 / 4 = 572 sq mm
The area of your hub is
Pi x 14 x 14 / 4 = 153 sq mm
The FSA is 572 - 153 = 419 sq mm
85% of that is 356 sq mm.
Doing the area calculation backwards from that gives a diameter of 21.3 mm.
quorneng is offline
Old 04-16-2016, 01:07 AM
TimMartel
Default Impeller for Turbo Hawk
Thank you Don.
Tim
TimMartel is offline
Old 04-16-2016, 02:09 AM
For those of us, like me, who abhor maths.
http://www.calculator.net/area-calculator.html
Old 06-01-2016, 11:52 PM
EFFlyer
I used SketchAndCalc to calculate the surface area of my EDF along with various other irregular shapes:
http://www.sketchandcalc.com
Watch the video on the homepage first... might save you some time
EFFlyer is offline
Old 06-02-2016, 12:26 AM
Build a jig for your thrust tube. One plug is sized the diameter of your fan shroud exit and the other plug sized to your preferred exit diameter. Space these on a dowel to the exact length you want (or scribe a line). This is also handy for trimming the duct square.
Old 06-02-2016, 12:29 AM
Now that's clever ! Thanks !
Electric Ducted Fan Jets
75
09-04-2018 02:35 PM
Crash Test Dummy
107
02-26-2013 08:20 PM
Theycallmecrash
10-08-2012 10:53 PM
wcc963
11-28-2007 08:16 PM
patrnflyr
01-15-2006 12:09 AM
Quick Reply: EDF and Pusher Jet Builder's Support
Page generated in 0.12723 seconds with 12 queries
