No cost wheel chocks from scrap wood.
Old 09-19-2018, 06:27 PM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Default No cost wheel chocks from scrap wood.
I'm building a .40 size twin from plans and put it on wheels for the first time last night so I could start checking and setting incidence. I needed it to stay still so as not to affect readings. I was using pliers and aluminum bars as chocks then I started thinking why not just make some wheel chocks? So I did. I rummaged in the balsa scrap box and dug out some 1" triangle stock and some 1/4" balsa stick. It took me all of about 10 minutes to measure, cut and glue together three chocks. Two are for 3" main wheels and one for the 2.5" nose wheel. Slopped some acrylic paint on 'em and they work like a charm. I tried using two unattached pieces of tri stock but they didn't work to my satisfaction. With the tri stock locked together the plane can't go anywhere. Even all square stock would have worked to build these. I just love the things I have made from that scrap wood treasure box.
I made my own bolt on motor incidence platform from scrap last night too. Uses the Harbor Freight digital level. Works awesome but it's motor size specific. I think I'll make another for the smaller motors too.
Joe
File Type: jpg
Turbojoe is offline
Old 10-09-2018, 04:20 AM
Porcia83
Great idea, thanks for sharing!
Porcia83 is offline
Old 10-10-2018, 12:15 PM
Guy in our club uses old kiddies boots ... cuts then short so wheel sits inside.
Must admit I have thought about chocks to stop my Extra from moving on runway even when idling .. but its how to pull them out while on the sticks.
Old 10-10-2018, 03:29 PM
Porcia83
I have been known at times to use my Crocs to stop my larger planes from moving around. Finally another use for them. Incidentally is wceeoi aware of what the holes on the sides of Crocs are for? It allows my dignity easy egress.LOL. I'm the first to admit they are generally a hideous shoe/sandals but comfort won out over vanity years ago.
Porcia83 is offline
12-10-2015 09:21 AM
Quick Reply: No cost wheel chocks from scrap wood.
Page generated in 0.04934 seconds with 14 queries
