spitfire
Old 11-10-2009, 12:35 AM
  #126
spitfire
Not the best
spitfire's Avatar
well, other than flooding my own topic I have made progress...
I converted the cad drawings to PDF, and they are ready to get reprinted...
and I found ALL the old pics that where on that site that got taken down...
here is the rcgroups thread I got them on:
http://www.rcgroups.com/forums/showthread.php?t=109673
and I have attached the pics...
credit goes to RCFlybry for the pics I believe
P.S. if he or another high in authority person does not want these pics in this post, PM me, I will take them down ASAP.
ID:	113108   Click image for larger version
ID:	113109   Click image for larger version
ID:	113110   Click image for larger version
ID:	113111   Click image for larger version
ID:	113113   Click image for larger version
ID:	113114   Click image for larger version
ID:	113115   Click image for larger version
ID:	113116   Click image for larger version
spitfire is offline
Old 11-10-2009, 01:32 AM
  #127
spitfire
Not the best
spitfire's Avatar
ok, so I have made a somewhat list of what I am going to use...
for servos I am going to use the Hitec (best... brand... EVER!!) HS-81, I already have two... I just need to buy one more... (thanks, NUTs for the servos... and burning out the third one on his spit )
and I will probably go with this inrunner, because the plans call for a brushed 400 speed... and sense the plane was designed around it, its just easier to get an inrunner rather moding it to put in an outrunner... the inrunner is just overall better for this type of nose anyway imo...
http://pulsosystem.com/motor/2212.html
thanks nuts for the ESC... it should work perfectly with this motor!!
just one thing I wanna know if your reading this, NUTs, is, what is it rated at? there is nothing on the ESC itself... so I don't have a clue what speed it is... I think its 500? because if I recall thats what your spit was... but I am pretty sure its over 400 so I should be good with it anyways...
alright... so I just need to get some glue, wood, covering, one servo, an inrunner, a couple of lipos, a charger, a new copy of the plans, some random stuff, and a partridge in a pear tree...
SPIT.
thanks: http://www2.wattflyer.com/forums/showthread.php?t=50530
Last edited by spitfire; 11-10-2009 at 01:37 AM. Reason: changed pair to pear... :-\... added a link to a helpful thread...
spitfire is offline
Old 11-10-2009, 08:23 PM
  #128
PaperAirplane
Subscribed...
PaperAirplane's Avatar
OK, I'll be watching. Just remember to cut the pieces a bit big and sand them to shape. It makes it much neater. And be patient. Sandpaper=good, weight=bad. Sand down every piece a bit before gluing to make it slightly thinner, except for the parts that must be thick. Good luck!
PaperAirplane is offline
Old 11-14-2009, 05:12 PM
  #129
TDisaster
TDisaster's Avatar
What is the wingspan?
I'm thinking that motor and hs-81's are way too heavy.
TDisaster is offline
Old 11-14-2009, 07:29 PM
  #130
spitfire
Not the best
spitfire's Avatar
its 30"
but it was designed in the 90s... with similar "micro" servos... and a can 400, and heavy batteries... so with lipos and a lighter motor than the can(at least I think it is lighter...) it should come about about the original weight...
I have a few HS-55s... I might swap them out if it gets to heavy... but I have heard people having problems with this airplanes tailweight...
so I think it will come out pretty light considering what was originally in there...
spitfire is offline
Old 11-14-2009, 07:36 PM
  #131
TDisaster
TDisaster's Avatar
Originally Posted by spitfire View Post
its 30"
Why not just build it as light as you can?
If you can use lighter components, why not? If you work on building the tail feathers light, then you shouldn't have any issues. Remember, an ounce on the tail, is 4 in the nose.
Old 11-14-2009, 09:15 PM
  #132
spitfire
Not the best
spitfire's Avatar
because that motor has got POWAR!!
and it would probably be safer to put the bigger servos on it if it goes really fast... eh, not quite sure... but whatever...
again... I may just put the HS-55s on there... but I will probably stick with that motor...
POWAR!!!
P.S. now, its sounds silly... but you CAN make it to light... my Dad made a model one time that would just sit in the air because there was a slight breeze... I doubt that will happen with my spit... so again, I may put the HS-55s on there...
spitfire is offline
Old 11-14-2009, 10:10 PM
  #133
TDisaster
TDisaster's Avatar
The fact is with a small wing like that, I doubt you really can't build it too light.
But then again it's your plane. If you want heavy, then that's up to you...
Old 11-14-2009, 10:20 PM
  #134
spitfire
Not the best
spitfire's Avatar
yeah... good point... I am considering the HS-55s anyway... another thing is, the lighter... the faster!
but thanks for bringing that up... I will keep it in mind...
spitfire is offline
Old 11-14-2009, 10:34 PM
  #135
spitfire
Not the best
spitfire's Avatar
Lightbulb
hmmm... what about this motor?
http://www.hobbycity.com/hobbycity/s...idProduct=4201
I think it would probably be a little better for it... as its shapped a lot more like the 400speed can... although its consider a 380speed... it would probably provide more power than even the 400speed can because its brushless right?
and its cheaper
spitfire is offline
pilgrim pete
Warbird Electrics
11
02-01-2007 09:53 AM
NUTS
20
11-17-2006 08:10 PM
new2rc
Warbird Electrics
08-01-2006 12:25 AM
nz builder
Scale E-Powered Aircraft
02-21-2006 01:21 AM
nz builder
Warbird Electrics
02-19-2006 11:07 AM
Quick Reply: spitfire
Page generated in 0.10619 seconds with 24 queries
