spitfire
Old 08-16-2007, 10:03 PM
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
Looks neat, but if it was me....I'd buy a modern airplane computer radio with the appropriate airplane mixes....
Biplane Murphy is offline
Old 08-16-2007, 10:27 PM
spitfire
Not the best
spitfire's Avatar
it has appropriate airplane mixes...
...and i can't fly two stick very well
spitfire is offline
Old 08-16-2007, 11:21 PM
Frank Voikel
Frank Voikel's Avatar
Well, there is only one way to get better....
Practice!!!
Frank Voikel is offline
Old 08-16-2007, 11:27 PM
spitfire
Not the best
spitfire's Avatar
well i like signal sticks but how much are two sticks??
spitfire is offline
Old 08-16-2007, 11:28 PM
Tinman
The Hot dog man
Tinman's Avatar
Same price pretty much...
Tinman is offline
Old 08-16-2007, 11:43 PM
spitfire
Not the best
spitfire's Avatar
then why shouldn't i get a single stick:<
spitfire is offline
Old 08-17-2007, 12:16 AM
Biplane Murphy
Two sticks provide more flexibility for later!!!
Old 08-17-2007, 12:18 AM
Lip84
Lip84's Avatar
Agreed...more stix is better. What happens when you put a POV system in your cockpit and need to use a stick to control the camera, the throttle/rudder, and the aileron/elevator? Gotta glue a third stick and gimble to your forehead or what?
Lip84
Lip84 is offline
Old 08-17-2007, 12:50 AM
spitfire
Not the best
spitfire's Avatar
OK two things,
one, let me tell you how to hold a signal stick, you rap your left hand around the transmitter and your ring finger works the throttle, and your right hand is on the stick and you twist it for aileron and turn it for rudder and push it forward and back for elevator!
two, lets try to keep it on topic, i don't want the moderator to lock this topic:<
spitfire is offline
Old 08-17-2007, 12:57 AM
efinkg
efinkg's Avatar
Default Perhaps a DX7, rather than 72 mhz
Just my opinion. if you plan to spend $340 on a transmitter get a DX7, so you won't have as many glitches/channel problems. If I didn't have 2 nice computer TX's on 72 mhz and a Spectra module i'd be flying 2.4 ghz for sure.
efinkg is offline
Old 08-17-2007, 01:04 AM
spitfire
Not the best
spitfire's Avatar
this transmitter is FM 75 MHz it won't get glitches
spitfire is offline
Old 08-17-2007, 01:26 AM
efinkg
efinkg's Avatar
Really "JR Century 7 Transmitter Receiver NER-527X 7 channel on 72.750" seems to me it is a 72 mhz Channel 24 transmitter. I sill suggest the DX7, if you plan to fly more than one plane on the transmitter(and getting another $340 per plane gets expensive. Fast.) a computer transmitter is worth the price just for the digital trims.
efinkg is offline
Old 08-17-2007, 01:37 AM
spitfire
Not the best
spitfire's Avatar
OK well you can change the Cristal, and futaba made a FM 75 MHz signal stick with digital display
spitfire is offline
Old 08-17-2007, 01:48 AM
spitfire
Not the best
spitfire's Avatar
now lets try to keep it on topic!!!
i don't want the moderators to lock it
spitfire is offline
Old 08-17-2007, 02:07 AM
Biplane Murphy
they won't close the thread for trying to decide on a transmitter....after all you can't really fly your future custom built Spitfire without one.
Old 08-17-2007, 02:12 AM
spitfire
Not the best
spitfire's Avatar
OK just trying to be careful thanks
spitfire is offline
Old 08-17-2007, 02:29 AM
Biplane Murphy
So....How big are you thinking for your "Spitfire"?
Old 08-17-2007, 02:39 AM
spitfire
Not the best
spitfire's Avatar
here is a good transmitter, and it has 9 channels
spitfire is offline
Old 08-17-2007, 02:43 AM
Biplane Murphy
I don't see a link....?
Is it the Futaba 9c? If so, now your talkin'!!
Old 08-17-2007, 02:48 AM
spitfire
Not the best
spitfire's Avatar
sorry, forgot to link you here, and i am going to make it 30" wingspan
spitfire is offline
Old 08-17-2007, 02:58 AM
Biplane Murphy
30"......cool...should be a nice parkflyer size.....
Well you really like those "oldschool" transmitters don't you?
If that's what you like Go for it!!
Just make sure you can get compatible recievers for it.
Old 08-17-2007, 03:08 AM
spitfire
Not the best
spitfire's Avatar
yep i just really like signal sticks and sense this one is FM i will be able to buy receivers for it!
and yes it should make a good parkflyer do to its small wing span
spitfire is offline
Old 08-17-2007, 03:43 AM
efinkg
efinkg's Avatar
Whose plans are you building from?
efinkg is offline
Old 08-17-2007, 01:55 PM
spitfire
Not the best
spitfire's Avatar
i got it from here (bottom of the page)
and i forgot to tell you that i want to put flaps on it
spitfire is offline
Old 08-17-2007, 05:15 PM
efinkg
efinkg's Avatar
Looks real nice, flaps are probably unecessary for performance based reasons, but the cool factor can't be denied. And you have already shown with your radio interests that you are hard to dissuade so: Good Luck, and turn this into a build log, I'm interested.
efinkg is offline
Quick Reply: spitfire
Page generated in 0.13885 seconds with 11 queries
