Airspeed, Altitude, Expanded Memory, and more sensors for the MicroPower eLogger - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Eagle Tree Systems, LLC discussion Discuss support issues and product questions with Eagle Tree Systems
Old 05-28-2007, 05:14 AM
billpa
Default Airspeed, Altitude, Expanded Memory, and more sensors for the MicroPower eLogger
Eagle Tree Systems, LLC is pleased to announce shipment of several powerful, low cost add-on sensors for our MicroPower eLogger!
Look at all you can learn about your model with your MicroPower and our low-cost add-ons:
  • HOW HIGH WAS THAT? Altimeter Expander (MPR-ALT-EXP) - High resolution Altimeter measures Altitude from 0-20000 feet (0-2400m) with approximately 4 foot (2 meter) resolution. Now you can prove (or disprove) claims about how high you flew, log your flight patterns, etc.
  • AND HOW FAST? Airspeed Expander (MPR-AIR-EXP) - Measures airspeed from 9-200 MPH! Full logging and graphing of your session's speed!
  • WHAT'S THAT BUZZ I HEAR? Servo Current Logger (SERVO-CURR-LOG) - Use your eLogger to find out how much current your servos are drawing. Logging of servo current draw is the one and only way to diagnose binding servos while in the field. Connects between your servo and receiver (or between your BEC/battery and receiver for multiple servo logging) to log current from 0-5 Amps continuous (surge measurement to 10 amps), with precision 0.01 Amp resolution. Also fully compatible with our Seagull and Data Recorder products!!
  • I WANT MORE! Multi-Expander (MPR-MULTI-EXP) - Expands your MicroPower to log Brushless RPM, Throttle stick movement, and simultaneous recording of two temperatures! Includes integrated Brushless RPM sensor and Y cable for Throttle monitoring. Temperature sensors sold separately.
  • I WANT TO LOG IT ALL!! Memory Expander (MPR-MEM-EXP) - Increases your MicroPower eLogger's onboard logging time by 5x!
All the sensors listed above can be used simultaneously or separately. And, they work with all versions of the MicroPower - support is only a web download away.
With our flexible, powerful system, data can be displayed and analyzed in three ways:
  • The live and maximum readings are displayed on the PowerPanel LCD Display. This is very useful for quickly seeing how high, how fast, etc., at the field.
  • The readings are logged in the MicroPower, for download to your PC.
  • The readings displayed and graphed (charted) with the Eagle Tree Windows application, or a spreadsheet program.
Remember, only the Eagle Tree MicroPower eLogger + PowerPanel LCD Display is both a powerful in-flight (in-car, in-boat) logger, and the world's smallest and lightest watt meter/bench monitor, all in one! And, no other logger offers anywhere near the range of features or sensors of the MicroPower!
billpa is offline
leybold12
Brushless Motor Construction
09-24-2008 05:15 PM
cyclops2
Electronic Builders Workshop
02-15-2008 04:18 AM
Moonwalker
11-02-2007 09:52 PM
billpa
Batteries & Chargers
10-11-2007 06:47 AM
Quick Reply: Airspeed, Altitude, Expanded Memory, and more sensors for the MicroPower eLogger
Page generated in 0.07247 seconds with 9 queries
