"5EZP" MOCKING-JAY VTOL from "Hunger Games" - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-19-2014, 03:37 AM
Bobdaeronort
Bobdaeronort
Default "5EZP" MOCKING-JAY VTOL from "Hunger Games"
I din't know if this is the correct name for it but it's what I'm calling it.
The VOL aircraft seen in the new Hunger Games Movie "MOCKING-JAY".
Here are the pics I found and my initial "5EZP" plan for it.
I imagine it to be much like my "5EZP" Boeing FX-II Sea Eagle.
https://www.youtube.com/watch?v=AnnwoeC3PEA
ID:	178420   Click image for larger version
ID:	178421   Click image for larger version
ID:	178422   Click image for larger version
ID:	178423   Click image for larger version
Name:	MOCKING-JAY FIGHTER wing plan 1.jpeg
Bobdaeronort is offline
Old 11-19-2014, 07:24 AM
Past President of PSSF
Almost looks like a F-117 with a hole in it.
It will be interesting to see what you come up with.
Wildflyer is offline
Old 11-20-2014, 04:02 AM
Bobdaeronort
Bobdaeronort
The rending of foam begins…
Upon reflection I revised the trailing edge of the wing.
I left the center cut-out in for alignment purposes.
It will be cut out later.
Name:	MJ pattern@3.JPG
ID:	178435   Click image for larger version
ID:	178436   Click image for larger version
ID:	178437   Click image for larger version
ID:	178438   Click image for larger version
Name:	MJ @ 2L.JPG
Name:	MOCKING-JAY PATTERN BEGINS.JPG
Old 11-21-2014, 02:22 AM
Bobdaeronort
Bobdaeronort
Had a couple hours to work on it this evening. Now watching 2013 Punki'n Chunki'n on Sci Channel.
ID:	178453   Click image for larger version
ID:	178454   Click image for larger version
ID:	178455   Click image for larger version
ID:	178456   Click image for larger version
Old 11-21-2014, 10:59 PM
Bobdaeronort
Bobdaeronort
Glides at sunrise
https://www.youtube.com/watch?v=_tx1lJ8a2Wg
Old 11-23-2014, 07:02 PM
Bobdaeronort
Bobdaeronort
Paint
Name:	CH Mockingjay!4.JPG
ID:	178476   Click image for larger version
Name:	CHS Mockingjay@11H.JPG
Old 11-23-2014, 08:54 PM
Given that I saw no sign of steering commands during your glide tests. I am assuming you had no RC equipment installed, yet your design shows very good stability, for a strange shape with almost no vertical stabilizers.
I believe you have a good plane that will fly great and turn a lot of heads at the field.
I am looking forward to the plans PDF
Thank you for sharing your designs, I will be building several of them.
Old 11-24-2014, 02:13 AM
Bobdaeronort
Bobdaeronort
Thanks Wildflyer.
I always test with minimal or no controls surfaces.
I think this will fly just like my Boeing FX-II Sea Eagle which it is quite similar to my Boeing FX-II Sea Eagle.
Here is a vid of my Sea Eagle.
Old 11-26-2014, 12:16 AM
Bobdaeronort
Bobdaeronort
Finally the wild winds calmed to [email protected] 7, gusting to 17 this afternoon so I took my "Five Easy Piece" Capitol Peacekeeper Bomber from the film "Mockingjay" out for her maiden flight. Whoa, did I have the CG wrong. I taped a AA battery to her nose , moved the li-po another inch forward, and added some down elevator to get her to fly.
My attempt to give the Bomber some additional details in the from of a double layered fantail proved to be problematic. This seemed to create some instability and the scale elevons were too much as well despite a 20% expo.
Not entirely happy with the maiden but I've learned from it. The crash busted her up pretty good.
I'm going to build another one with what I've learned from this one. This should fly as well as my "5EZP" Boeing FX-II Sea Eagle. We shall see.
https://www.youtube.com/watch?v=9HF_RtIXPLM
Old 11-27-2014, 12:10 AM
Bobdaeronort
Bobdaeronort
Mockingjay Capitol peacekeeper Bomber II glide tests.
My second attempt at this model. This time I got the CG right and tested it with the motor and Li-po onboard to make sure I got it right.
https://www.youtube.com/watch?v=jKAVank-2XY
Old 11-29-2014, 02:50 AM
Bobdaeronort
Bobdaeronort
My second attempt at the build and true to my original concept.
https://www.youtube.com/watch?v=XbA0YjZt3dg
Old 11-30-2014, 01:36 AM
Bobdaeronort
Bobdaeronort
A sunset spin with the Mockingjay bomber
https://www.youtube.com/watch?v=Tx0JZDuUhDk
Old 12-26-2014, 08:16 PM
Bobdaeronort
Bobdaeronort
https://www.youtube.com/watch?v=IM5waOr2-OA
Old 01-02-2015, 08:15 PM
abborgogna
Really amazing! I don't suppose you have plans available for the Mocking-Jay? I would love to build and fly one.
abborgogna is offline
Old 01-03-2015, 12:08 PM
Bobdaeronort
Bobdaeronort
Hopefully very soon.
I've built it twice and I think I have got the pattern debugged now.
Here is another flight of it.
https://www.youtube.com/watch?v=QQNOIlwVw0c
Old 02-21-2015, 12:38 AM
Bobdaeronort
Bobdaeronort
Finally.
Here is the PDF plan for the "Mockingjay" PANEM Bomber.
http://www.mediafire.com/view/mn5t69...NEM_BOMBER.PDF
Page generated in 0.12416 seconds with 31 queries
