Where is the C of G on the F-15 Eagle? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-28-2010, 02:48 AM
r4pt0r
r4pt0r's Avatar
Default Where is the C of G on the F-15 Eagle?
would someone please post a pic of an f-15 with the CG labeled?
r4pt0r is offline
Old 04-28-2010, 04:20 AM
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
you can find it your self with this....
http://adamone.rchomepage.com/cg_calc.htm
VERY handy
Possum
hillbillynamedpossum is offline
Old 04-28-2010, 02:39 PM
Bill G
Super Contrubutor
Bill G's Avatar
With several swept wing planes, I have found the geometric calcs to place the CG aft of ideal, or flyable in some cases, for that matter. For whatever reasons unknown, it would seem the inner wing area has more effect on stability and determines the CG than the outer area. A chuck glider using the same wing as the finished plane produced the same results once for me. With the added weight, the finished plane wanted a CG much further forward. In summary, while rearward sweep moves the CG rearward, it is not as much as would be expected.
Bill G is offline
Old 04-28-2010, 04:21 PM
tiloldar
Default Ty
I like that site. It even gives the stall speed.
Is it pretty accurate w/o swept wings?
Tilo
tiloldar is offline
Old 04-28-2010, 08:40 PM
r4pt0r
r4pt0r's Avatar
Default found it!
[media]http://origin-images.rcuniverse.com/forum/upfiles/29000/Nl29465.gif[/media] here it is for any one who needs it in the future.
r4pt0r is offline
Old 04-29-2010, 03:45 AM
Rode the short bus
The c/g calc gives a pretty good starting spot. I usually set up my plane accouding to that to start with. I usually leave the prop off and run around the yard making vroom- vroom noises and tossing the plane around for a few glides. By moveing the battery around and looking at the glide path a man can get a real good idea of how many pieces the plane will break into on the test crash.
Possum
Old 04-30-2010, 03:00 AM
Bill G
Super Contrubutor
Bill G's Avatar
Possum
Gotta make whoosh-whoosh noises. It's a jet.
Bill G is offline
pvtzemerak
Electric Ducted Fan Jets
70
02-19-2010 02:31 AM
pvtzemerak
8
07-08-2008 04:53 AM
blanket
04-08-2008 02:10 AM
PerlAddict
13
04-06-2008 08:10 AM
easytiger
58
06-26-2006 12:32 AM
Quick Reply: Where is the C of G on the F-15 Eagle?
Page generated in 0.08522 seconds with 13 queries
