Ultra-Micro Mustang - brushless - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 02-21-2010, 10:11 PM
JazzMan2001
JazzMan2001's Avatar
Default Ultra-Micro Mustang - brushless
Hello, my first post
Here's my Parkzone P51 Ultra-Micro Mustang flying it's first few batterys:
I'm pretty much a beginner although I did try flying a few times many years ago (about 16 I think) and I spent quite some time practising in Realflight.
Naturally I bent up the original fuselage and tail a bit, did a number of repairs on the tail which seems to be the weakest spot of the original.
Decided to rebuild the plane and add a brushless setup to it - mainly to make it more efficient and add a little more power.
I bought new foam bits for the rebuild which I strengthened with carbon rod on the weaker spots that I had found during my early flights with the BNF one.
I used an AP05 motor, XP-3A ESC, GWS 5x3 prop, a prop saver mount and a piece of carbon fibre to mount the motor:
Servo horn mount glued in
Linkages taped down
Wing glued down
Cutting ruts for carbon re-enforcements - these will help keep the fuselage straight on a harder nose first landing
Carbon glued in
With extra tape hinges adding - the hinges can come apart on harder impact.
Hole cut for carbon
Carbon rod glued in - this is a very good mod as the tail is very fragile
Servo glued in and tested - have since put it on the more aggressive setting but the servo throw needs to be limiting or the servo and lock up.
Wing glued on
Elevator glued and re-enforced with a thin carbon rod. I added extra tape hinges.
Tail glued in, the carbon goes right down in the fuselage
AR6400 glued in and ESC trial fitted
The motor mount is a piece of 1.5mm carbon fibre cut to shape and air holes added (to aid in cooling the internal electronics)
Prop & prop saver test fit
The spinner need quite a but of hacking up to fit
Tail re-enforcements
Had a little oopsy with some solvent on this side so I've replaced the missing bit with a chunk of the old fuselage
The gap here is a bit bigger than I would have liked but its OK.
The internals running:
Flown it about 15 times since the rebuild and it's much improved - stability and power.
I'm using the bigger 150mah batteries and a DX6i with some expo set on the ailerons and elevator. It does seem a bit zippyer with the smaller 120mah batteries due to the weight saving
It just needs stickers now to finish it off.
JazzMan2001 is offline
Old 02-22-2010, 01:27 AM
smokejohnson
smokejohnson's Avatar
Nice work Jazzman...looks good.
Welcome to Wattflyer
smokejohnson is offline
Old 02-22-2010, 08:08 AM
JazzMan2001
Old 03-26-2010, 08:27 PM
SirSudiSavage
Hey man nice work you got me all worked up to make mine brushless =) I just have one question for you before i make my order for the brushless parts how did you attach the prop on to the brushless motor ?
SirSudiSavage is offline
Old 03-26-2010, 08:40 PM
JazzMan2001
I used the prop adapter 3rd one down on this page: http://www.micronradiocontrol.co.uk/prop_adapter.html
It has the great advantage of being on a rubber band so if you land with the prop sticking downward it offers some protection againts breaking the prop or the shaft on the motor
Old 03-26-2010, 09:23 PM
SirSudiSavage
i broke my prop shaft today when flying inverted (and stupidly low) and the wind picked up. a replacement setup is 15 bucks and going brushless is only 10 bucks more (for the esc) so i said why not =) i will give it a try btw: im copying your system =P
Old 03-26-2010, 09:33 PM
JazzMan2001
hehe I spent a lot of time researching mine online before buying those bits. Yesterday I ordered a variety of GWS props to try out and see if it makes any difference. I've got a stock Sukhoi that I'm going to try various props on as well
Old 03-26-2010, 09:51 PM
SirSudiSavage
im wondering what runtimes you are geting with the brushless setup? i just ordered 17 138mah batts for mine along with the brushless setup i think i will never run out of battery any more lol
Old 03-26-2010, 10:00 PM
JazzMan2001
More than stock, but its been very cold recently so I've not been able to get a good idea of run time. The little lipos don't work that well in cold temps. I've been warming them up on a radiator and keeping them in my pocket before flights which has helped a lot.
It's starting to warm up now so I should have longer flight times
Old 04-06-2010, 02:38 AM
sgomes
EXCELLENT work!!
There are quite a few guys over at RCGroups who have done this mod, only to find out it is not much better than stock. The real jump seems to be going to 2S, but I think you would need another esc for that.
Here is one for the Sukhoi http://www.rcgroups.com/forums/showp...postcount=1413 He uses the AP03, but I think the AP05 would be even stronger.
I don't think the esc would be very expensive, and likely it would be a drop-in.
Again, very nice work.
sgomes is offline
Old 04-06-2010, 08:46 AM
JazzMan2001
Thanks Steve Yeah I'd need a different ESC for 2S.
I've also bought a Sukhoi (they were going for very good prices before the new models release).
I had an interesting comparison with the Sukhoi, it's still stock. My brother has the Sukhoi with the same conversion as I've got in the Mustang.
The brushless one is quite a bit quicker than the stock one but you do need a bit more momentum for some stunts. It's not hugely quicker but it is noticeable when both are flying.
I've also tried a variety of props on the stock Sukhoi - the 5030 seems to work well. Even that it still slower than the brushless.
Old 04-24-2010, 08:28 PM
SirSudiSavage
Ok all my parts came in the mail today =) im starting my own BL P-51 project
Also man can you take a closer pic of the way you mounted the motor wires to the plug that came with the ESC
Old 04-24-2010, 08:35 PM
RU55EL
Novice Member
RU55EL's Avatar
Originally Posted by JazzMan2001 View Post
...I've also tried a variety of props on the stock Sukhoi - the 5030 seems to work well. Even that it still slower than the brushless.
I really like the GWS 5043 prop on my stock Sukhoi.
RU55EL is offline
Old 04-24-2010, 08:57 PM
JazzMan2001
I did try the 5043 but it seemed a bit strained. I might do a bit more experimenting some day
Awesome keep us updated
Old 05-19-2010, 11:16 PM
rariho_4180
Where did you get the carbon rod? I'm looking at Hobbyzone.com but I don't know what it is.
rariho_4180 is offline
Old 05-20-2010, 08:09 AM
JazzMan2001
I'm in the UK so used: http://www.micronradiocontrol.co.uk/carbon_fibre.html
Most recently I bought some at a local hobby shop. You can also try kite suppliers but from what I've seen they tend to be more expensive.
Old 12-10-2011, 03:13 AM
Brick
small Member
good info here on the BL build...i'm new, so i had to subsribe to this
Brick is offline
Old 12-10-2011, 10:33 AM
JazzMan2001
Thanks I've since converted this to 2S using a XP7A ESC and 240mah Hyperon 2 cells. It works really well like that, did the same on the Sukhoi
Old 12-11-2011, 12:20 AM
Brick
small Member
man that thing boogies !!! i'm going 2S also...i especially like all the frame support mods you did to the P-51
Brick is offline
Old 12-18-2011, 01:07 PM
bmrmiller
bmrmiller's Avatar
What size CF rod did you use? 1, 1.5, 2 mm? I am rebuilding my UM P-51 and liked this improvement, want to include it in mine.
Thanks.
bmrmiller is offline
caltrop
E-Flite Helicopters
156
03-19-2010 06:36 AM
KrashTestKev
01-29-2010 07:42 AM
C140
28
01-08-2010 10:18 PM
wayneabonga
Foamies
12-22-2009 03:03 PM
hobbyshopguy
01-18-2007 04:18 PM
Quick Reply: Ultra-Micro Mustang - brushless
Page generated in 0.08365 seconds with 10 queries
