parkzone motor specs needed - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-19-2008, 03:38 PM
adwb
Default parkzone motor specs needed
Hi, Any one know what are the specs for the ParkZone BL400-15T brushless with gearbox , as fitted to their 3d typhoon?
kv, max amps, ect??
regards
Alistair
adwb is offline
Old 10-22-2008, 12:46 PM
Bob O
AMA 489725
Bob O's Avatar
I search the Internet high and low and couldn't find a thing on it......sorry.
Bob O is offline
Old 10-22-2008, 05:46 PM
adwb
thanks, that the problem I had, I found some info on parzone website,
but they list 2 x bl400 with differnt kv but the one fitted to the Typhoon has no lable or details on it
alistair
adwb is offline
Old 10-25-2008, 04:38 AM
cv640
I am not 100%, but I am pretty sure it is the 3700kV version of the park 400. There should be some info about that somewhere.
cv640 is offline
Old 10-28-2008, 09:08 PM
Bob O
AMA 489725
Bob O's Avatar
The owner of my LHS says its 5000kv . Sounds pretty high to me, but I didn't debate it with him since I don't know any better. LOL! Besides, he treats me well so I'll just stay on his good side.
Bob O is offline
Old 10-28-2008, 09:53 PM
flydiver
flydiver's Avatar
It's not likely 5000kv. Probably either 3700 (15A) or 4200 (18A). I'd guess 3200.
You can get specs of the efilite from here since that's what they likely are or are very similar:
http://www.e-fliterc.com/Products/Motors.aspx
flydiver is offline
Old 10-29-2008, 09:39 PM
Dr Kiwi
Maybe close enough to this Feigao 130L 2040-15T: http://www.bphobbies.com/view.asp?id...4&pid=B1848539
Yours may be ~3700Kv.
Dr Kiwi is offline
Old 10-29-2008, 10:35 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Yeah, it won't be 5000 Kv... Himax makes a motor which (in my opinion) the Park 400 is a direct copy of...
Based on that, my guess is that your motor is a 4100 or 4200 KV motor.
EDIT --> I found this link on Wattflyer. I'm not sure of the source, but it says the motor is 3700 Kv.
Old 11-03-2008, 01:44 AM
Bob O
AMA 489725
Bob O's Avatar
Found it!
ParkZone PKZ4116
3700 kV 15 turn stock replacement
http://secure.hobbyzone.com/catalog/...s/PKZ4116.html
Bob O is offline
Old 09-05-2010, 08:28 PM
Lawndart2
Since I didn't want to build a new fire wall mount, I am going to try a few more rpm with the Park 400 4200K inrunner in my Typhoon, as much as I would like to get rid of the gear drive I thought I would try this first.
The stock BL gearbox is 8:1 and with 4200K it should swing a 13-8 all day with out exceeding 30 amps burst. But with the higher Kv I think a 12x8 should perform well. The stock props are 12x8.75 and 13.5x7 and look to be SF with the broad blade width. It's been hard finding a replacement prop that works as well as the stock 12x8.75 in 3D slow performance and vertical climb rate but hopefully with the 4200k the 12x8 should pull well.
Lawndart2 is offline
Old 09-07-2010, 09:08 PM
Lawndart2
Well l have abandoned all that was previously said in my last post!!!
the shaft size on the park 400 is smaller then the OE 400 3700kv motor. so instead of hunting for a 10 tooth gear that would work I just scraped the idea...!!
So this is what I did.....
Went down to the local Hobby People store and found they now have there own new house brand of outrunnners. So I did a little research on witch motor would serve my Typhoon the best and settled on the fact that More Power is almost always better and went with a 2814-06 that spec's out like this..
lipo 2-4
io(A) 2A
6 turn
Max Kv 1290
Max. cont. Amp 24
Max Burst 32A/60s
effic. 80%
Mohm 45
shaft 4.0mm
103 grm.
14 pole
Timing 20-30 (High)
My Typhoon came equipped with a 30A 35 burst speed cont. from the factory so this motor fits this parameter (no I have not put a watt meter on it)
To mount it I used a 4mm ply wood and built an additional fire wall and used the three mounting screws from the gear drive setup and mounted the new fire wall up to the plastic OE fire wall, I got blind nuts to fit into the plywood that the new motor mount will screw up to using about 5/8" length spacers on 20mm socket head screws threw the motor mount then
threw the spacers and finally into the wood fire wall with blind nuts.
All I had in the way of a prop was a 12x8e and let me tell you it freaking halls arse!! and the vertical climb is limitless not to mention only needing 4 feet of runway...... I will pick up a smaller prop today because it's way to fast for 3D flying, I use only a third of the stick for most all manuvers.
barrytreadaway
05-13-2008 04:18 AM
aero_k
23
04-25-2008 12:26 AM
Micro_R/c.co.za
09-22-2007 10:26 PM
Moonwalker
Delta & Flying Wings
09-26-2006 07:50 PM
rattusrex
10
12-30-2005 01:52 AM
Quick Reply: parkzone motor specs needed
Page generated in 0.10259 seconds with 12 queries
