Do you know what is FPV system??? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
General RC items For Sale and WTB List tools, RC simulators and any other RC related item that is generally classified
Old 09-01-2008, 10:04 AM
AEORC
Banned
Default Do you know what is FPV system???
FPV---First Person View ,a very advanced equipment with high practicability for flying your models.
As I know,there are not more than 5 factories producing it in the world,
but known by many people and becomes more popular now.
The following are some details about it.
*includes:①Head Movement Tracking System ② small camera③ATX10 2.4G audio-visual transmitter④ARX 2.4G audio-visual receiver⑤7.4V800mAh lipoly for receiver⑥11.1V800mAh lipoly for transmitter⑦pan/tilt(including two 9g servoes)⑧2-3S lipoly charger
*Head Movement Tracking System(for example,X-GYRO1000):
X-GYRO 1000 is a kind of two axis head movement tracking system, based on high technology of sensor technique, designed for tracking complicated three-dimensional motion like head movement and so on, it can also be used on the areas of controlling drones and robots, transferring three-dimensional motion signals from hands, head of human to corresponding movement system on RC model, drone or robot.
The basic version of X-GYRO 1000 is specially designed for RC models with FPV(First Personal Version), it can be used perfectly with main stream transmitters that gets self defining trainer channel on market or to be co-operated with wireless high frequency modular independently. It can transfer the checked movement signals to transmitter, and the transmitter can send out signals of head movement or position of head( on two axis), so that the real synchronization can be realized when screen on the goggles displayed video pictures, users can look around as if he were inside the RC model. Since it is compatible with transmitters on nowadays market, it is easy and simple to use it and grasp it its best advantage is that no need any fixed reference object to check and measure the inflection position of RC model, and no drift at all when it in stationary state compared with other facilities that need to make use of very complicated reference facilities or manual controlled transmitter, mechanical arms or other tools are heavy and not easy to be carried along, it greatly limited users’ freedom.
X-GYRO is compatible with high end FUTABA transmitters (FF-7, FF-8, FF-9, T9Z, T12MZ, T14MZ) supporting trainer/student function by using 6 pins square trainer connector. These transmitters can supply power for X-GYRO, no need external power. It can generate same standard PPM signal and merge selective pan/tilt signal channel into PPM, and then send it to model (default: channel 7 and channel 8 respectively, user can also define the channels for themselves), the system can send standard PPM signal to those unused channels, X-GYRO1000 can support those transmitters which can let users make choice on channels controlled by student (except of 1-4 channel) and controlled by trainer when mistake happens.
Since the FUTABA transmittersespecially the FF9/9C series),trainer switch is momentary switch, only if you leave it always “on” can realize its function. The simplest way for it is to hold the switch on with a rubber band. Other high-end transmitters such as (T9Z, T14MZ) have already put the trainer channel to always “on” channel.
If you know or interested it,please post what you know or feeling.
Thanks!
ID:	76890   Click image for larger version
ID:	76891   Click image for larger version
ID:	76892   Click image for larger version
ID:	76893   Click image for larger version
ID:	76895   Click image for larger version
ID:	76896   Click image for larger version
ID:	76897   Click image for larger version
AEORC is offline
Old 09-01-2008, 01:36 PM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
price?
FlyingMonkey is offline
Old 09-01-2008, 01:38 PM
FlyingMonkey
Flite Test Fan
http://www.aeorc.com/english/product_130.html
Old 09-01-2008, 01:48 PM
AEORC
Banned
You mean the C11 FPV COMBO?
AEORC is offline
Old 09-01-2008, 01:49 PM
AEORC
Banned
C11 FPV COMBO Includes:①ARV1000-A CCD480 cameraATX700 2.4G audio-visual transmitterARX 2.4G audio-visual receiver7.4V800mAh lipoly for receiver11.1V800mAh lipoly for transmitterpan/tilt including two 9g servoes)⑧2-3S lipoly charger
AEORC is offline
Old 10-10-2008, 07:20 PM
j33p3r
Default So, How much is the Item: C11 FPV COMBO shipped to USA??
Just enquiring how much is this http://www.aeorc.com/english/product_130.html
shipped to USA? zip code 53085
jp
j33p3r is offline
Old 10-11-2008, 01:46 AM
AEORC
Banned
jp
Of course shipped to USA.
PM sent!
AEORC is offline
Old 10-11-2008, 05:05 AM
aviatordave
aviatordave's Avatar
How come your site doesnt list prices?
How much for this (US$):
AVR510
aviatordave is offline
Old 10-11-2008, 07:13 AM
AEORC
Banned
AVR510
We are factory managing wholesale operation ,so there is no retail price on the site.
For the AVR510 price,PM sent.
Hu
AEORC is offline
Old 10-11-2008, 07:27 AM
AEORC
Banned
There are some version of head displays:
AVR510:High Resolution Head Display, head-wear,resolution:640H*480V*RGB(922K)
AVR410:Standard Head Dsiplay, head-wear,resolution:320H*240V*RGB(922K).
AVR310:Entry Level Head Dsiplay, head-wear,resolution:800*225(180K)
AVR520:High Resolution Video Goggle Display,goggles style,resolution:640H*480V*RGB(922K)
AEORC is offline
Old 10-11-2008, 01:19 PM
aviatordave
Got the pm. Thanks Hu.
autorail1
Aerial Photography
8
08-25-2008 03:05 PM
stinkweed007
Aerial Photography
30
06-25-2008 02:02 AM
jeff2215
Aerial Photography
9
05-06-2008 03:56 AM
Crash9
Aerial Photography
11
04-17-2008 04:07 AM
Crash9
Video Parking lot
12-27-2007 05:07 AM
Quick Reply: Do you know what is FPV system???
Page generated in 0.07419 seconds with 23 queries
