Curtiss Wright T-32 Condor - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-01-2020, 07:23 PM
skyhawk940
Default Curtiss Wright T-32 Condor
Building from plans. 82 inch wingspan, electric twin.
ID:	187984   Click image for larger version
skyhawk940 is offline
Old 05-02-2020, 02:02 AM
That's a cutie.
... electric twin.
Keep battery wires short, extend motor wires.
However, if that is not possible/incovenient:
too long wires batteryside will kill ESC over time: precautions, solutions & workarounds - RCG
Old 05-02-2020, 02:50 PM
skyhawk940
Thanks for the info. I'm newer to electric power systems and I love twins. I am an Electronics Eng. I'm figuring 70 to 90 amps to each motor depending on the weight of the plane. There is no weight info on the plans. I've ran 12 gage copper wire through the wing to feed the EMC's. I've built an OV-10 Bronco that has about 440 watts max and it works great.
I'll take some measurements and post.
Old 05-02-2020, 03:01 PM
skyhawk940
So far...
Old 05-02-2020, 07:38 PM
park
Clear !
park's Avatar
Your work looks great !
park is offline
Old 05-02-2020, 11:26 PM
... I love twins ...
Will you be using righthanded and lefthanded props, counterrotating?
... I'm figuring 70 to 90 amps to each motor ...
Current drawn is proportional to pitch, #blades, voltage≤, Kv≥, gearing≥ and prop-diameter⁴.
Power drawn differs only for voltage, proportional to voltage≥.
extra current with one or two cells added, simple table - RCG
... depending on the weight of the plane. ...
Plane type and mass are leading when choosing power (in watt). The first link is a good start, otherwise it would be a bit too much.
Old 05-02-2020, 11:28 PM
Note that Kv (in rpm/volt) says absolutely nothing about motor max.power, max.current, max.torque, efficiency.
Kv only depends on desired rpm and battery voltage: Kv = RPM_noload / voltage.
It does effect current and power drawn greatly though, both are proportional to Kv cubed.
And below an excellent quote about motor selection.
From
brushless motors Kv?.
The reason I suggest picking Kv last, is that prop choices have bounds - the diameter that will physically fit and the minimum size that can absorb the power you want. On the other hand, combinations of voltage and Kv are much less constrained - at least before you purchase the components.
So Kv is not a figure of merit, in that higher or lower is better, it is simply a motor characteristic that you exploit to make your power system do what you want, within the constraints you have, e.g. limited prop diameter, if it's a pusher configuration, or if you already have a bunch of 3S packs and don't want to buy more, and so on.
Minor lay-out changes by RvS
anklebiter
11
11-29-2018 09:47 PM
ewilliam
01-21-2014 06:32 PM
phillipmorris
10-31-2011 10:42 PM
Albatross
07-25-2011 03:46 AM
Quick Reply: Curtiss Wright T-32 Condor
Page generated in 0.05291 seconds with 13 queries
