SC Servo Noise at full stick - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-11-2007, 05:10 AM
marchino61
Default SC Servo Noise at full stick
I was testing my newly rebuilt (again!) Super Cub yesterday on the bench.
I replaced the firewall, cowl and prop, and replaced the wing strusts with a carbon fibre strip epoxied to the centre of the underside of the wing. Needed to add another 11g weight (=20 cent coin) to the nose - I did not weigh the strip, but it seems it must be relatively heavy. AUW gone from 700g when I removed the landing gear to about 740g now. 22g of that is to get the CoG (just) ahead of the CoL rather than behind it.
All seemed ok except one of the servos made a humming noise when held at the full stick position (in one direction only).
ACT was off.
Any ideas?
marchino61 is offline
Old 06-13-2007, 12:10 AM
jperch
jperch's Avatar
Typically when a servo buzzes, especially at the extremes of movement, it is caused by a mechanical binding in the the linkage somewhere. Try disconnecting the servo from the linkage and see if it still makes noise. If not, then it is binding.
Basicaly, the mechanical structure is preventing the servo form moving as far as you are commending it to. This is not a good situation. This can lead to early servo failure and excessive current draw. It is best if you can correct this.
I hope this is helpful,
Joe
jperch is offline
Sir Raleigh
ParkFlyers
23
05-05-2008 04:32 PM
mlamb01
04-19-2008 03:50 PM
rx20040
01-02-2007 05:23 AM
ShokWaveRider
Standard & Large E-Heli Talk
09-20-2006 06:48 PM
Twmaster
08-23-2006 01:43 AM
Quick Reply: SC Servo Noise at full stick
Page generated in 0.06300 seconds with 14 queries
