Shop reorganization project
So as the old adage goes, no matter how much space we have we tend to fill it up. I got tired of continually hunting stuff and moving planes around to work on or even just to get to other planes to go fly or whatever.
When I bought this house the shop was unfinished and the walls were in this uncovered insulation state. There was some OSB sheets in the shop that were intended for the walls but all my stuff got moved in and all set in front of them so that corner became the catch all to stack whatever I wasn't using at the time.
So this past week my son was in from College for spring break and we tackled it. cleaned it all out, threw out a bunch of crap, put all the boards we had (will be getting more to finish) and built these plane racks to get everything up off the floor. I hate wheels with flat spots!
Still got a ways to go but feel much more relaxed now when I am out in the shop and don't see all that clutter, and can actually see the floor!
Past President of PSSF
I have installed 4x12 5/8" sheetrock on a cathedral ceiling by myself with one. On the ceiling drive nails at the joint at top center and start there, working your way down to the sides. It is easier that way.
Just place the sheet on the hooks and crank it up, it will lock in place, then move your ladder and screw it on.
It won't work well on the walls.
However you don't get to be an old carpenter like me without a few tricks.
Use a real good C-clamp clamped to a point above the center of the place where you want the panel. screw a 2x4 block on the panel (don't try this with sheetrock) to fasten a line form the panel to the back loop of the C-clamp and back down to the ground. If you have a small block and tackle, use it to raise the panel. Fasten the line off very well and then fasten the panel to the wall.
As you might guess, I had to do a lot of 2 man jobs by myself.
If you have questions PM me and we can trade phone numbers.
Hey that's the best way to do it.
I just bought an OLD pallet-jack for $60, that cheaper than 1 mobile base for my bigger tools.
I will just make or modify bases so that the jack can slip under them. Then I can move them anywhere in the shop.
