Lemon Telemetry Module for Spektrum TXs
I recently found out about this module and thought I should share.
Lemon-RX has released a Spektrum TX Compatible full range telemetry system.
http://www.lemon-rx.com/shop/index.p...product_id=124
Here's their specs:
Specification
Type: Spektrum compatiable full range telemetry system
Measurements: Rx V, Batt. V, current (60A max.), capacity consumed (mAh), altitude selectable absolute or sea level (Altimeter), internal or external temperature measurement selectable, brushless motor RPM, telemetry packet missed counter (0 to 100%) for reception estimation
Modulation: DSMX (DSM2 Compatible)
Band: 2.4 GHz
Dimension: 37.5(L) x 27.5(W) x 9(H) mm
Weight: 7.3g for Telemetry Electronics, 8.8g for V/I/mAh sensors
Voltage Range: 3.45 - 7.2V
You basically get everything you need including sensors for $44.80. It's not compatible with the Spektrum sensors, but comes with most that you would want anyway. The next time I need a module, this is what I plan to try.
Here's their specs:
Specification
Band: 2.4 GHz
Looks very good for many users but I generally put telemetry in my big helis and they are 12s powered and pull over 150A, so this units 30v / 60A limit is a complete show stopper for me, otherwise I'd have ordered at least three right away.
The 7.2v input limit is also a concern but I'm hoping that's not a hard limit and it would cope with powering off a 2s LiPo direct (8.4v max) as almost all receivers do these days.
Does wattflyer have a 6KW award?
I've got kind of a long story... I bought a used unit from a user over on RcGroups. He listed it as working, but with XT60 connectors that he put on. The sensor didn't seem to work at all when I got it, but looking at how others made the same conversion I noticed something. The connectors were reversed, the current was flowing the wrong way. Positive and negative were correct. I reversed the connectors and it started working.
But.... now anytime the current draw went above 30 amps, the telemetry read 0.... This apparently was a bug is some of the early units. I contacted LemonRx hoping for a discount on a unit. They sent me a new one for free!
The new unit works great. I've attached some pictures of the telemetry current and voltage from both the telemetry module and a EMeter2 I now have. The telemetry reads close. Within 3% or so. The current reads just a little high on the telemetry module.
EMeter2 Graph
Telemetry Graph
Here's a graph of all of the data from an actual flight.
I've been using a freeware Spektrum telemetry data viewer that works pretty well. TLMViewer,
http://www.tlmviewer.com/index.htm
The only shortcoming I see with the Lemon system is the lack of antenna information. Fades/Holds... That type of data.
So far I'm pretty happy, but I've only had a handful of flights with it so far.
EMeter2 Graph
Telemetry Graph
i also am trying these rx's for the first time and i must say it worked great today.
steve, wow!! thats a lot of graphs your displaying....
,i hope they are showing positive results on the newer lemon rx's. todays flight was on a 6channel with satellite rx mounted out on the wing. i have a micro 6ch lemon i plan on installing on a smaller quad sometime. they are so affordable ,it doesn't hurt to stock up.
03-06-2012 10:34 PM
09-25-2011 07:19 AM
THESANDMAN
08-28-2011 04:11 PM
d12bn
07-25-2011 03:03 AM
Mechcondrid
28
10-25-2010 01:26 AM
