The Wattflyer Sailplanes Thermal Duration Contest
Keep the sunny side up
Hello everyone and welcome...
I am happy to announce the start of a new awards/contest here on wattflyer today.The wattflyer electric sailplanes thermal duration contest.
The rules of this contest are simple & will be given shortly but basically the goal of this contest is to see how long you can keep your sailplane thermalling after a quick motor run-up of 45 seconds or less,winch,hi-start or d.l.g. Anyone who is able to achieve 30,45,60,90 or 120 minutes of continuous thermalling will be awarded a new icon under their avatar name in the awards showcase section.
To receive your new icon simply PM Don with a link to your post or simply ask for assistance in doing so.
Many Thanks to Don for giving the go ahead to start this award and to Aeajr for providing the rules for the contest.
Here are the rules & I hope you enjoy your participation in this contest.
Now go out there and find those BOOMERS
BIG SKY - THERMAL SOARING
1) From a fresh hi-start,winch,hand or ground launch you can run the motor for up to 45 seconds, then you turn the motor off and you can not restart it. Reclimbs are not permitted. If you restart the motor the flight time is no good.
2) Motor time starts as soon as you apply throttle. This is an LMR, Limited Motor Run contest with a pretty long motor run allowed so that the motor run itself does not provide much advantage to anyone. Many will choose to shut off the motor in less than 45 seconds. No credit for shorter motor runs.
3) Soaring time starts when the sailplane releases or the motor goes off. Either you time the whole flight and subtract the motor run or you use two watches, one to time the motor run and one to time the flight. I have multiple timers on my radio so I can do this with my radio alone. How you do this is up to you.
4) You can time your own flight if you wish. You are on your honor. Time is truncated to the second. No fractions and no rounding. Read the seconds only.
5) Landing must be within 100 feet of the original launch location or the flight does not count. Landing must be on the ground/grass or pavement. Landing in a tree, bush, structure or other elevated spot that would not normally be a landing spot does not count. There are no other rules around the landing.
6) Time stops when the glider comes to a rest. So the clock keeps running if you clip a branch, or go to land and bounce back into the air. When the plane stops, time stops.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground/hand. No reclimbs permitted.
8) Report your best time of the day by posting here. You can post as many times as you like, but only 30,45,60,90 & 120 minute icon thermal awards will be given. You can fly as many days as you like to work toward your best time. The goal is to achieve personal bests in the fun atmosphere of a contest.
Comments - You are welcomed AND HIGHLY ENCOURAGED to report anything you like about the day, the flight. Pictures, videos, gps plots, etc are welcome but not required.
What if the "motor" is a winch? Or a Hi-Start? At what time does the clock start? Release of the tow-line? When the the aircraft levels out? Granted the difference between the two events will be only a second or three, but you are counting to the second, and you know how competitive some people are, even if the differences in flight times is only that much...
Heres a couple pictures of my e-plane.The sonic by black horse.Its got a turnigy 35-42 motor with a 12x6 prop on 3cells 2200 mah batery.It only takes about 20 seconds for it to get too small to see
Its actually called a hotliner but there seemes to be some confusion right now in the r.c. community as to what is a hotliner
So far Ive only managed about 14 1/2 minutes of thermalling so Ive got some work to do dont I
There is a poll going to to see if we will change the rules to include non-E-power sailplanes and slope models.
http://www.wattflyer.com/forums/showthread.php?t=63829
Go vote!
Personally, I think if its capable of soaring it should be allowed - no matter how you get it into the air
Hot liners are at an even bigger disadvantage because they tend to be over powered and so even heavier.
Higher wing loadings - all else being equal - makes for a faster flying model and a higher sink rate.
The next big issue is wing span. Span loading - or actually span squared loading - is more important than wingloading as far as good glide performance. So wing span is your best friend when it comes to thermaling.
Thats why all the top contest models have large wing spans. They may also have hi wing loadings, but the lower span^2 loading more than makes up for that.
Again, hot liners tend to have 2 meter or less spans and are again at a disadvantage.
That said - when its blowing and turbulent, they will tend to do better. They will still soar and can thermal. They do require you to fly a little better and find stronger lift than if you were flying a pure TD machine.
My Siren was the same way. it needed stronger lift and you have to watch closely to see indications of lift - it does not signal lift well. But when you get in a good core, it will climb just fine.
When you catch your first thermal its a real thrill. You will be hooked for sure then
Im working on a couple of projects now to see just how light a power system you can get by with in a sailplane.
The vast majority are over powered and so have a lot of extra weight. I want to see if I can build some e-sailplanes that do not weight any more than the pure un-powered versions.
The goal is to be able to launch without the hassle of hi-starts or winches and still thermal with no penalties.
Im converting an old 2x6 glider now. When its done Im starting on a 112" span Mirage RES sailplane and I'll add e-power to it as well.
Both will be with the smallest setups I can get to work. Im starting out with CDrom motors and very small packs - around 3 ounces for the entire power system.
We will see how it goes.
I have a couple of questions.....
Whats the official start date?
Is it going now with the current rules, or are we waiting to see if the new rules get voted in?
Can we use times from last week or last month or only new times after the official start date?
Thats all
Thats all
It started on the 1st post of this thread.
Do you have something to report?
I went out today & only got 12:48 myself but the real boomers dont kick in till winter around here.
11 Sept @ 13.00-Top Model Avia today went 36.40 with a 22 second motor run to with motor shut down by CAM switch @ 200 meters. Launched into a brick lifter and only landed to drain the morning coffee or it could have been an hour easily....maybe longer.
well sorry I'm about to head off for a week of flying and some flights are sure to be over an hour but wont have time to think if its legal under the rules or not lol, enjoy it and good luck to everyone
Helinut, dont give up on the Radian. We have a monthly event that is designed around the Radian. Yesterday, virtually everyone was pushing the time limit of 10 minutes,
Check out the "club contests" section for Electroglide:
www.sefsd.org
and our Facebook Page with details:
https://www.facebook.com/pages/Silen...6756394?ref=ts
The Radian is a completely capable ship. Get the balance right, get her trimmed a touch fast, and she will tell you where the thermals are.
Hang your thumb on the elevator, and she slows down too much to really create thermal hunting lift.
What are you using for battery?
Yeah, based on the reports Ive read, the Radian's are doing very well in the new ALES soaring contests. In some cases, they are winning out over Ava'a, Supra's etc.
That may be due, at least in part, to there being so many of them
Still, they are winning and placing in many contests.
So the plane is capable. You could be having trouble 'keeping it up' for any number of reasons though
It could be anything from plane set-up issues - CG, trim settings, control throws, radio programing for camber control, etc - to technique problems or maybe the location your flying from just isnt good for thermals.
Id check around and see if there are any soaring contests going on in your area and go to some of them. You will learn a ton in no time and get your plane dialed in correctly all while having a blast. Most guys are more than willing to help with all aspects of soaring.
www.sefsd.org
www.sefsd.org
Im as guilty as anyone. Seriously, I dont think its practical to try to limit content. People just love to chatter
P.S. For a second there I thought you were talking about starting a "pure sailplane" award thread - as opposed to an e-sailplane thread
