stick responses
Old 03-03-2008, 07:54 PM
neilg.
Default stick responses
with the xc2 the more i fly it seems my controller is unresponsive until i am about halfway forward, back, left or right on sticks. how can i get more sensitivity with my controller.
if this makes any sense to you experienced flyers.
neilg. is offline
Old 03-03-2008, 08:42 PM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
What you can do is move the control arms OUT one hole on the servo arms. They are most likely in the INSIDE hole right now. The hole needs to be opened up a little with a small drill or with an exacto blade. Just a little.....you don't want the control rod being loose in the control arms.
You will find that this makes a LOT of difference in how it reacts to stick input.
Heli Jim is offline
Old 03-04-2008, 03:56 AM
neilg.
i think they are on the outside hole. looking at the 3in1 side of helio, the servo linkage is on the last hole on the right. move it to the left 1 hole?
neilg. is offline
Old 03-04-2008, 04:20 AM
Heli Jim
Heli Jim's Avatar
Move it to the 2nd hole OUT from the center of the servo
Heli Jim is offline
Old 03-08-2008, 10:33 PM
neilg.
moved servo linkeage. the response is like night and day. the cx2 reacts quite differently.
neilg. is offline
Old 03-08-2008, 10:37 PM
Heli Jim
Heli Jim's Avatar
Glad I could help
Have fun! GO FLY!
Heli Jim is offline
Old 03-09-2008, 03:52 PM
gfdengine204
gfdengine204's Avatar
I was flying my CX2 last night and when I push forward, the heli goes forward, then stops, then goes forward, then stops. One of the other guys looked at it and said I had some slop between the inner and outer shaft (he could pull the top rotor head up about 1mm, said I needed to get rid of the slop). Would that be enough, or do I need to move my servos links out also?
gfdengine204 is offline
Old 03-09-2008, 09:20 PM
Heli Jim
Heli Jim's Avatar
What you are seeing is the two rotors working against each other. The bottom set of blades is telling the heli to move forward and the top set is saying No, NO...be stable.
Kind of normal for a co-axial
You can move the control rods out one hole on the servo arms and that helps a little
Heli Jim is offline
Old 03-09-2008, 09:22 PM
gfdengine204
Thanks Jim.
Someday I am gonna be good like you.
11-10-2021 03:35 PM
Benson1
Foamies
06-23-2008 02:25 AM
Sam_K
12-31-2007 06:37 AM
Idaho
01-20-2006 03:04 AM
Quick Reply: stick responses
Page generated in 0.10251 seconds with 13 queries
