Blade cx2 questions
Old 11-04-2013, 07:54 PM
dontrinko
Default Blade cx2 questions
Sorry if this is a dupe but I can not find my other post.
I have a Blade scout and a CX2 with the 3 in one. The scout came with a stuck servo but once I got the moving it flies fine.
The CX2 I have trouble with . I think most of the time the problem is not a big enough living room to make adjustments. At best it moves around a little during attempted hover.
I attempted to fly it outside once. Not good but it survived.
I have several questions.
1. I ordered the Replacement tail. Will it help indoor flight?
2. I am new at this. Are there any other mods that will make it easier to fly indoors?
3. Is there anything available that is larger than the Scout but smaller than the CX2 for indoor flight?
4. If I replace one blade should I replace both?
Thanks; Don
dontrinko is offline
Old 11-04-2013, 08:33 PM
Hi dontrinko.
1. Hate to sound like a smart-alec, but what replacement tail? I think the cx2 is fine as long as it has some mass as a tail. I've tried without a tail and it isn't pretty!
2. The aluminum swash plate and balance bar holder (I forget the technical term for that) make the controls a little less sloppy. The cx2 is a bit large for in a house. I was using it in a warehouse.
3. It's not bigger than the scout, but the mcx2 is a nice flyer. Our if you're just looking for anything to fly inside to keep your fingers trained, I gave in and got a nano qx quad copter and it's a blast! And I'm no big fan of quads. It's more stable and more maneuverable than the mcx2.
4. I don't think so. I haven't flown my cx2 in a while but I think I only replaced one at a time.
One thing about flying heli's or quads indoors, is flying low or close to objects causes turbulence. It's easiest to hover higher and away from anything so the rotos are working in clear air.
Old 11-04-2013, 09:35 PM
dontrinko
The replacement tail is from Boom town, carbon tail with plastic fins. I have read that it makes outdoor flight easier but you still need calm wind. Don
Old 11-05-2013, 12:49 AM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
You can replace one rotor blade if it breaks, but you need to make sure
that the PAIR of blades are balanced. take both blades (off the heli) and
screw them together. Then balance them on the balls between two glasses or the
jaws of a vice, or whatever. Add a little scotch tape to the light blade till
they sit level.
Heli Jim is offline
Old 11-05-2013, 01:39 AM
It might help a tiny bit, but that upper rotor is designed to keep a zero relative wind condition. So if there is any wind, it will try to fly with it, and you'll be fighting it with the lower rotor.
dontrinko
Multi-Rotors
12-19-2013 04:00 AM
TomKnollRFV
E-Flite Helicopters
07-24-2013 08:42 PM
DCDetector
General RC E-Heli Talk
10-03-2012 08:27 PM
uncledaddy
06-17-2011 01:04 PM
Old Blade Man
Beginners - Helis
05-14-2011 01:01 PM
Quick Reply: Blade cx2 questions
Page generated in 0.06794 seconds with 15 queries
