PAK DA Bomber in Five Easy Pieces
Old 03-04-2014, 02:28 AM
Bobdaeronort
Bobdaeronort
http://youtu.be/Hx0PSzp_wfs
Bobdaeronort is offline
Old 03-09-2014, 03:17 PM
jmrpb
jmrpb's Avatar
Great airplane as usual. Amazing look!
I love the way you make the fuselage. It really looks awesome.
Follow your dreams and fly like there is no tomorrow!
Bernardo
Lisbon, Europe, Portugal
jmrpb is offline
Old 03-20-2014, 02:19 AM
Bobdaeronort
Bobdaeronort
https://www.youtube.com/watch?v=TYiOCjlmQmA
Old 04-12-2014, 01:38 PM
Bobdaeronort
Bobdaeronort
The BEB (Blue-Eyed-Babe of Babe-CAM fame) supplies the background music singing "WHITE RABBIT".
https://www.youtube.com/watch?v=Bt-8Toq9HpI
Old 09-22-2014, 02:39 PM
Bobdaeronort
Bobdaeronort
https://www.youtube.com/watch?v=d7rPH4uI51Q
Old 09-30-2014, 01:47 AM
Bobdaeronort
Bobdaeronort
https://www.youtube.com/watch?v=QsyQf1eYPks
Old 10-09-2019, 11:31 AM
ROCKETCHRIS
Thank You Mr. Daeronort for all your effort and kindness to create and post all the wonderful videos and free plans. I am recovering from a major illness and your plans and videos have been inspirational to me and also my kid who is studying to be an aerospace engineer. I just finished building your 5EZP PAK DA BOMBER (PAK BAT FA FSW). My kid and I are going for the maiden flight this coming weekend. Will post pictures soon when I figure out how to do it. As I understand from your video , the cg point is at the rear wing tip. Again , thank you for all the hard work and giving the plans away is an incredible gesture of kindness.Im going to build your YF 60 next.
ROCKETCHRIS is offline
Old 10-11-2019, 06:12 PM
ROCKETCHRIS
https://docs.google.com/document/d/1...it?usp=sharing
Thank you again Mr. Daeronort ! Here is a photo of our Bat Pak Fa FSW my kid and I built. We are going to maiden it tomorrow if the weather holds up. It is equipped with a Grayson Hobbies Microjet V3 , Flite Test 35 Amp ESC and a Luminaire 2250 battery. I got stuck on the Forward 3d fuse canopy for a while, but I glued back in the wing pice which was originally scored and folded downward to make the lower fuse and then cut new pieces for the lower fuse and mated them to the wing. This allowed us to have a flat service to build the upper and lower forward fuse on. We really enjoyed the build and we can't wait to start work on the 5EZP YF 60. Thank you again for designing plans which look to the future. Again , thanks for the awesome design !
Old 10-12-2019, 03:26 AM
ROCKETCHRIS
I almost forgot . Our all up weight on the new build fsw Pak Bat Fa is 18ounces and we are using a 6x4 APC prop/ Also, we used Mr. Daernort's method of attaching the carbon spars with bi directional reinforced strapping tape rather than the traditional (cut a spar slot , epoxy and fiberglass cloth method )of attaching the spars to the wing. It sure saves time and is lighter .
Old 10-12-2019, 03:57 PM
ROCKETCHRIS
https://www.dropbox.com/s/0kvhu7axsm...B1%5D.mp4?dl=0
SUCCESSFUL MAIDEN VIDEO ATTACHED : BAT PAK FA FSW
SHE FLEW ROCK SOLID WITH SURPRISING SPEED FOR A SMALL GHMJV3 motor. Also, the hand launch was surprising stable as well. It's more stable than our tomhe f22 ! Our CG was a little nose heavy , but hey ! - Its a maiden flight. Can't say enough good things about Mr. Daeronort's design - He definitely does his R & D before releasing a plan. We are very pleased.
Old 10-12-2019, 04:00 PM
ROCKETCHRIS
https://www.dropbox.com/s/13uq9fmwco...B1%5D.jpg?dl=0
This is a picture of my son with it!
Old 10-13-2019, 01:15 AM
Bobdaeronort
Bobdaeronort
Great flight ROCKETCHRIS!
Once you get her dialed she is really smooth flyer.
Good Job!
Old 10-20-2019, 01:51 PM
Bobdaeronort
Bobdaeronort
Don't forget the bead of HOT-GLUE to help bond the carbon to the foam.
Old 10-20-2019, 05:51 PM
ROCKETCHRIS
Default Flew the pak bat fsw in the rain !
Thanks For the tip Sir ! My son and I just got in from Flying the Pak Bat FSW . Unfortunately , we got caught in the rain - What fun ! We used a lighter battery in the same position and improved the CG .
Old 10-21-2019, 01:18 AM
Bobdaeronort
Bobdaeronort
Hey check out this report on the new Russian T-60 program for a sixth generation fighter.
If you switched the wings forward it would be a dead ringer ( Or vice-versa ) for my PAKDA design.
Old 10-21-2019, 12:39 PM
ROCKETCHRIS
Default Kind of like a sea eagle with canards !
https://youtu.be/TYoOEs-kzx8
Kind of like your FXX Sea Eagle With Canards ! Maybe someone could make like Clint Eastwood in the movie Fire Fox and borrow the Russian design for an RC model ? Thank you for posting the video clip - very cool !
Old 11-29-2019, 12:37 AM
ROCKETCHRIS
Default Best cog for pak bat fsw .
After having flown the 5EZP PAK BAT FSW for ten flights now , we have determined the best center of gravity location (for us) I thought I would pass the information along for the benefit of others. We have found (for us) that the best center of gravity location is achieved by measuring inward along the trailing edge of the wing from the wing tips a distance of 1.25" inches. See photos attached.
ID:	187738   Click image for larger version
Humor
05-03-2012 05:11 PM
Quick Reply: PAK DA Bomber in Five Easy Pieces
Page generated in 0.13282 seconds with 17 queries
