Pattern aircraft Discuss electric powered pattern aircraft in here
Tower/Hobbico 110 servo experience
Old 07-31-2012, 02:03 PM
luckymacy
Default Tower/Hobbico 110 servo experience
Anyone have any experience with the TS or CS 110 servo Tower sells?
On paper it seems to be a no brainer for use in small electric pattern plane but I can't find any searches on multiple user forums where anyone has used them for anything and has any opinion one way or the other.
Micro Digital High Speed Servo
http://www3.towerhobbies.com/cgi-bin...?&I=LXUDS3&P=7
SPECS: 4.8V 6.0V
Speed: 0.16 sec @ 60 0.13 sec @ 60
Torque: 36 oz-in (2.6 kg-cm) 46 oz-in (3.3 kg-cm)
Length: 1.2" (30mm)
Width: 0.5" (13mm)
Height: 1.1" (28mm)
Weight: 0.6oz (18g)
Voltage: 4.8V-6.0V
luckymacy is offline
Old 08-09-2012, 07:06 AM
dumpsterjay
It's all in the thumbs
dumpsterjay's Avatar
I'm using some of the larger Hobbico servo's in my glow powered planes. the specific sizes are the C126 and the C140. Both are Digital servo's. I'm going to assume (And that's a dangerious thing to do, As we all know what to assume means) that they are HiTec clones, Because they use the same gear set as some models of HiTec servo's.
I've not had any trouble with the C126 and the C140 Servos, But I haven't any experience with the smaller Hobbico servos, But I would expect the same reliability from the CS110 as I'm getting from the larger servos.
I use Hyperion Atlas Digital servo's in All of my EP planes. I've never had a problem with them either.
I don't know if this helps you or not, But maybe others will post that have used the CS 110 servo.
J
dumpsterjay is offline
x-nitro
3D Flying
16
02-25-2016 02:58 PM
k-vette
9
02-06-2012 01:13 PM
RCFlyer44
22
03-29-2011 04:55 AM
Quick Reply: Tower/Hobbico 110 servo experience
Page generated in 0.09135 seconds with 13 queries
