Dynam Albatros
Old 06-28-2015, 04:53 AM
WVrailfan
WVrailfan's Avatar
Default Dynam Albatros
I have A Dynam WACO which has turned out to be one of my favorite planes. It is a good size, easy to see, but easy to transport. It flies great and is easy to land.
So when I was looking for a second biplane, the Dynam Albatros DVa seemed a likely choice. It is the same size and can use the same 4s batteries. Judging from the videos on line it is a good flyer also.
I got one, painted it so it doesn't look like every other Dynam Albatros and headed to the field.
Maiden flight was down right scary. I balanced it at the recommended location, but upon takeoff it was obviously drastically tail heavy. I managed a soft crash in the hay field adjacent to our runway, causing only minor damage.
Through trial and error, I have finally got it flying, however it took 5 ounces of lead up front and switching to a larger 3600 battery to get it balanced.
If anyone else is considering this plane, I suggest for the maiden flight add some extra weight to the nose so that it seems nose heavy at the recommended CG and work from there. Also, it takes a lot of rudder with ailerons to get it to turn, so be ready for that.
All that said, it is a very good looking plane, on the ground and in the air. With a little detail work and added rigging, it has a very scale appearance.
It likely won't replace my WACO as my "go to" biplane, but I will take it to the field once and a while for something different.
Jim
ID:	181145   Click image for larger version
ID:	181146   Click image for larger version
ID:	181147   Click image for larger version
ID:	181148   Click image for larger version
WVrailfan is offline
Old 06-28-2015, 05:00 AM
Looks great! I however, would opt for a much longer scarf.
Old 06-28-2015, 05:10 AM
I always do a CG calculation check. I find that many RTF/ARF models recommend the CG be in the wrong place.
Dynam models have recommended what turned out to be 12% to 55% MAC when the general rule of thumb is 25% to 35%. I never do a test flight with CG behind 30%.
Old 07-01-2015, 01:51 AM
flyhighhobbies
Jim
Wow thanks for posting, I thought I was the only one to add nearly 11oz to the nose. I as well maidened with the battery full forward and it was almost disastrous. It took off great then immediately knew it was nose heavy by the tail in a 3d position. It would turn one way but not the other. (Learned I had to use rudder and aileron on bi planes) and I was able to feather it down but it was a ride.
flyhighhobbies is offline
azcat
WWI Era
02-10-2014 11:50 PM
chestnutree
14
06-19-2013 02:38 PM
Maladroit
Warbird Electrics
11
03-11-2012 11:19 PM
02-29-2012 07:02 PM
Nieuport Fly Guy
08-19-2011 12:52 AM
Quick Reply: Dynam Albatros
Page generated in 0.06592 seconds with 21 queries
