My 4th homemade rc plane Carf Yak 55
Old 11-18-2017, 07:30 AM
ayubkhan5130
Default My 4th homemade rc plane Carf Yak 55
Wing span :....... 60 inch
Fuselage Length:...52 inch
Power :.......... .Electric
Test Voltage :... .14.8v (4S)
Maximun current :....40A
Maximum Power :...........470W
Motor :........... FA 3015-7t
Prop :............ 12x6
ESC :............. 50 A
Battery :......... 14.8 V 4 Cell Li-Po 2200 mAh 25C
Accessories :.... 5 = 9 gram Servos.
Flying Weight:... 1665 gram including everything
PLAN:............. Make plan with different images of Yak 55
Building Time:.... 40 days
Making video= https://www.youtube.com/watch?v=FbjHoex86T8
Flying video= https://www.youtube.com/watch?v=zcyn86YZM-0
ayubkhan5130 is offline
Old 11-18-2017, 02:44 PM
riverrat
circa: 1946
riverrat's Avatar
Awesome!
riverrat is offline
Old 11-19-2017, 02:51 PM
riverrat
circa: 1946
riverrat's Avatar
Default Covering Method?
ayubkhan
Is there any chance you have videos of you
covering your great builds?
I sure would be interested in viewing them!
I think others would be also!
Regards
Jimmy
riverrat is offline
Old 11-19-2017, 06:17 PM
ayubkhan5130
Originally Posted by riverrat View Post
ayubkhan
Regards
Jimmy
Thanks, you can watch this video to guess covering job, this is my 3rd plane,s video:
https://www.youtube.com/watch?v=ASaARPZVajY
Old 11-19-2017, 11:41 PM
Nice scratch build, Just a suggestion, add 3 degrees of down thrust to the motor, set the Cg at 25% from the front edge, and land a little faster you have better control of the plane with more air speed when landing, the plane when flying looked a little tail heavy, as the rear of the plane looked to be tilted down when flying. Take care and have fun, Chellie
Old 11-20-2017, 06:20 PM
ayubkhan5130
Yes you are right,, the tail was heavy,,, actually that was first flight.. now every thing is okay... Thanks
Old 11-24-2017, 07:27 PM
ayubkhan5130
I will make a new flying video.
Old 09-24-2018, 07:12 PM
ayubkhan5130
05-28-2020 09:50 PM
Reformed Nitroaddict
07-29-2017 08:15 PM
06-28-2017 04:22 PM
Saucerguy2
02-15-2011 12:59 PM
harrys
3D Flying
12-11-2010 10:26 AM
Quick Reply: My 4th homemade rc plane Carf Yak 55
Page generated in 0.07795 seconds with 14 queries
