"5ezp" north american f-86 sabre
Old 12-06-2014, 07:50 PM
Bobdaeronort
Bobdaeronort
Default "5ezp" north american f-86 sabre
A decommissioned F-86 Sabre was displayed on the corner of the Vigo County Courthouse grounds at the intersection of Ohio Street and US-41 back when I was a kid. A Local American Legion Post took custody of it ten years ago and now it sits on their lot. When I was a kid and I thought of Jets I always thought of the Sabre jet at the County Courthouse.
So here I go again. I've already cut out a working pattern and begun the parts registration.
The "Five Easy Piece" North American Aircraft F-86 Sabre.
It will be constructed much like my recent Aero L-39 Albatros and Douglass A4E Skyhawk with a "C" shaped fuse and be driven by a Grayson Hobby Super-Mega-Jet Motor on a 2200+mah 3S power set-up.
ID:	178652   Click image for larger version
ID:	178653   Click image for larger version
ID:	178654   Click image for larger version
ID:	178655   Click image for larger version
Name:	Sabre Pattern.JPG
Bobdaeronort is offline
Old 12-06-2014, 09:30 PM
Good start Dont forget that I get to do the Maiden Flight on this Bird when its done LOL
Old 12-08-2014, 02:34 AM
Bobdaeronort
Bobdaeronort
Okie-dokie.
Old 12-09-2014, 03:43 AM
Bobdaeronort
Bobdaeronort
Tonight's work on the pattern.
Still working on the inner structure which will reinforce the outer shell and provide a space to locate the Li-Po and RX, etc.
The AA's taped inside are nose weight for glide testing.
ID:	178717   Click image for larger version
Name:	sabre mockup@2H.JPG
ID:	178718   Click image for larger version
Name:	Sabre mockup@10.JPG
Old 12-09-2014, 10:55 PM
Bobdaeronort
Bobdaeronort
Internal Fuse and nose sorted out.
Name:	Sabre's Maw w internal fuse.JPG
ID:	178726   Click image for larger version
Name:	Sabre maockup Internal fuse @6.JPG
ID:	178727   Click image for larger version
Name:	Sabre mock-up2@10.JPG
Old 12-10-2014, 11:24 PM
Bobdaeronort
Bobdaeronort
SABRE GLIDE TESTS
https://www.youtube.com/watch?v=V9B7uvqYExc
Old 12-11-2014, 04:47 AM
Bobdaeronort
Bobdaeronort
More work done tonite. Took her all apart and began gluing her back together after her glide tests.
Added 3mm CR down her leading edges to stiffen her 50" wings in addition to the 5mm CR spar. Also added a 2mm CR cross brace at the forward rudder tab to arrest the tendency for the rear fuse to twist in a tight turn (may want to do this on the L-39 and the Skyhawk too). Now she's stiff and ready for Gizmos.
Get ready Chellie, she'll be ready for her maiden flight pretty soon.
Also today I received confirmation from the former Base Commander's son that the 181st squadron at Hulman Filed in Terre Haute did have and fly the F-86 Sabre in the 60's.
Name:	5EZP Sabre @10H.JPG
ID:	178742   Click image for larger version
Name:	5EZP SABRE Ventral.JPG
ID:	178743   Click image for larger version
Name:	5EZP SABRE @6.JPG
Old 12-13-2014, 12:50 PM
Bobdaeronort
Bobdaeronort
From the Global Security WEB Page:
F-86 "Sabre"
The F-86, the US Air Force's first swept-wing jet fighter, made its initial flight on October 1, 1947. Originally designed as a high-altitude day fighter, it was subsequently redesigned into an all-weather interceptor (F-86D) and a fighter bomber (F-86H). Armed with six 50 caliber machine guns, the Sabre pilot had to be in visual contact with the enemy in order to attempt a shoot-down, thereby making it the last true 'dogfighter' in the Air Force inventory. Before production ended, nearly 10 000 Sabres had been produced in 20 different variants (including the Navy FJ series known as the Fury), with five different engines. . Some of these variants had major design differences; consequently, the F-86 must be considered as a whole family of related aircraft.
During its long service life, the F-86 formed a part of the air forces of 24 different countries. As late as 1980, eight Developing nations still included a number of F-86 fighters in their inventories. Production lines were established in four foreign countries, with the last aircraft coming from the Japanese line in 1961. The Sabre saw extensive service with the USAF during the Korean war, in which it achieved an outstanding exchange ratio of nearly 14 to I in combat with the Soviet-built MiG-15. Surely the F-86 must be ranked, along with its illustrious World War 11 ancestor the P-51 Mustang, as one of the great fighter aircraft of all time.
The F-86 Sabre was originally designed for the US Navy in 1945 as a straight-winged jet fighter, and was derived from the XJ Fury. North American Aviation, already famous for its P-51 Mustang and B-25 Billy Mitchell bomber, was put under contract by the US Army Air Force to produce a new jet fighter. Utilizing information captured from the Germans, innovative technologies were employed in transforming the straight-winged XFJ-1 into the swept-wing F-86 Sabre that would dominate the skies over Korea in the 1950s.
The Sabre represented many firsts in technology and design. Swept-wing configuration has become a standard for jet-powered aircraft. The then revolutionary but now commonplace 'flying tail' allows the aircraft excellent maneuverability at high altitudes. In addition, the Sabre employs a hydraulic system for the movement of the flight controls, eliminating the excessive control stick forces necessary to maneuver other types of airplanes at high speeds.
Identifying features of the F-86 are the graceful sweptback wing and the nose inlet located in the fuselage. The 4.78-aspect-ratio wing of 35 sweepback was derived from captured German data for the advanced Messerschmitt fighter under design study at the time hostilities ended. Streamwise airfoil-section thickness ratios varied from 9.5 percent at the root to 8.5 percent at the tip.
Pitch-up was prevented on many versions of the aircraft by full-span leading-edge slats. As on the Messerschmitt Me 262, deployment of the slats was automatically initiated at the correct angle of attack by aerodynamic loads acting at the leading edge of the wings. On some versions of the aircraft, the slats were replaced by a sharp, extended-chord, cambered leading edge. Single-slotted high-lift flaps and outboard ailerons were incorporated in the trailing-edge portions of the wing. The ailerons were hydraulically actuated, as were the horizontal-tail surfaces, which, on the F-86E, consisted of a movable stabilizer with linked elevator. Some versions of the F-86 had an all-moving, slab-type horizontal tail with no elevator. Greater control effectiveness is possible at high-subsonic and supersonic Mach numbers with the all-moving horizontal tail, and this arrangement was to become standard on future transonic/supersonic fighters. The hydraulically actuated controls of the F-86E were of the fully powered, irreversible type with artificial control feel provided for the pilot. Fully powered, irreversible controls aid in eliminating such instabilities as aileron and rudder buzz, in addition to permitting maximum deflection of the control surfaces without requiring excess physical effort on the part of the pilot. These controls differ from the hydraulically boosted [294] controls used on some early versions of the F-86, as well as on other aircraft. In a boosted control system, the pilot is still directly linked to the aerodynamic control surfaces, but his strength is augmented by a hydraulic booster. Dive brakes were mounted on either side of the fuselage behind the wing.
Another identifying feature of many versions of the F-86 was the fuselage nose-inlet installation. Inlet air was ducted under the cockpit and delivered to the turbojet engine located behind the pilot; the exhaust nozzle was at the rear end of the fuselage. To minimize the depth of the fuselage in the cockpit area, the shape of the duct leading from the inlet to the engine was changed from a circular to an elliptical shape with the long axis being in the horizontal plane. In the all-weather interceptor versions of the aircraft, notably the F-86D, K, and L models, the distinctive nose inlet was replaced by a chin installation to provide space in the nose for the necessary radar gear. In contrast to other F-86 variants, the all-weather interceptor models were equipped with afterburning engines to provide the high rates of climb and high-altitude capability necessary to execute interception missions.
Armament of the fighter versions of the aircraft consisted of 3 .50caliber machine guns buried in each side of the fuselage near the nose and provisions for carrying 2 1000-pound bombs or 16 5-inch rockets on the wings. Interceptor versions of the aircraft carried 24 2.75-inch rockets mounted on a retractable tray contained in the bottom of the fuselage. The tray extended only long enough to launch the rockets. Environmental control in the cockpit consisted of air-conditioning, heating, and pressurization; in addition, the pilot was equipped with an ejection seat.
The thrust-to-weight ratio of the F-86E was about the same as that of the P-59A. Yet, as compared with the earlier aircraft, the Sabre showed a speed advantage of nearly 300 miles per hour at sea level. A smaller wing area, wing sweepback, and thinner airfoil sections, together with careful attention to aerodynamic design, were responsible for the large increment in maximum speed between the two types. Also, improved engine performance, not reflected in the values of static thrust given in the table, no doubt played a role in the superior performance of the F-86. Drag area was a little greater for the F-86 than for the P-80 by an amount that corresponds closely to the difference in wing area of the two aircraft. As would be expected, the zero-lift drag coefficients were about the same for both aircraft. Comparison of values of the maximum lift-drag ratio shows the P-80 to have had the advantage by about 17 percent; this difference is primarily due to the lower wing aspect ratio of the F-86. Although the Sabre was strictly a subsonic aircraft, low-supersonic speeds could be achieved in a shallow dive. Flight through Mach 1.0 first took place on April 26, 1948.
The Sabre was delivered to the Air Force in 1948. The first production model flew on May 20, 1948, and on September 15, 1948, an F-86A set a new world speed record of 670.9 mph. Originally designated as the F-86A, the Sabre would undergo a number of changes resulting in a variety of model designations.
Known for its combat role in the Korean conflict, this aircraft was single-handedly responsible for turning the tide of the air war in favor of the United States. As a day fighter, the airplane saw service in Korea in three successive series (F-86A, E, and F) where it engaged the Russian built MiG-15. The F-86 Sabre was introduced in November 1950 and rushed to Korea to challenge the tactical edge of the MiG-15. The MiG's pilots were very good, being (for the most part) veteran Russian fliers. But the USF soon had a counter to the MiG-15-the superb F-86A (and later, F-86E/F) Sabre. Many of the Sabre pilots were veterans of World War II and their expertise showed. Soon the Sabres and MiGs were mixing it up over northwest Korea, an area that became known as "MiG Alley." On December 17, 1950, Lt. Col. Bruce Hinton was the first Sabre pilot to score the first of an estimated 818 MiG-15 kills.
A General Electric J47-27 engine powered the F-86F; producing 6,000 pounds of thrust the aircraft can achieve a speed of 695 mph and can exceed the speed of sound in a shallow dive. It is capable of climb rates up to 10,000 feet per minute and can fly as high as 50,000 feet. The -F was used both as an air superiority fighter and fighter-bomber during the latter stages of the war; replacing the F-80 and F-51 aircraft still being used in the Korean combat in 1952.
While the war turned into a stalemate on the ground, MiG Alley remained a hot spot throughout the war. For a time the B-29s continued bombing targets in northwest Korea by day, but when MiG-15s shot down five Superfortresses in a week in October 1951, the big bombers began attacking only at night. Day after day, though, the Sabres (joined by F-84 Thunderjets or F-80s) swept into MiG Alley to meet the MiG-15s rising from their fields in Manchuria. Although the U.S. government directed that these fields were "off limits" to the FEAF aircraft, some of these planes occasionally strayed across the border in "hot pursuit" of enemy aircraft.
By the end of hostilities, it had shot down 792 MiGs at a loss of only 76 Sabres, a victory ratio of 10 to 1. In the hands of skillful pilots, the Sabre's 10-1 Kill ratio over the MiG-15 was the best achieved in any sustained fighter campaign. Of the 40 pilots to earn the designation of 'ace' (five or more kills) during the Korean war, all but one flew the F-86 Sabre. By July of 1953, no fighter aircraft in the world could take on the Sabre without being at a disadvantage. It is no wonder the F-86 Sabre is widely acknowledged along with the P-51 Mustang and the F-4 Phantom- as one of the three great fighter aircraft in US history.
Over 9,800 F-86s were manufactured during the years of 1947 through 1957, making it the most prolific jet fighter ever produced. More than 5,500 Sabre day fighters were built in the U. S. and Canada. The airplane was also used in the air forces of twenty other nations, including West Germany, Japan, Spain, Britain, and Australia.
Warner Robins Air Logistics Center (WR-ALC) had logistics management responsibility for the guns, communications, fire control and bombing-navigational equipment installed on F-86 aircraft. From 1953 to 1958, under Project High Flight, more than 500 F-86s were processed through the WR-ALC maintenance shops to prepare them for ferrying across the Atlantic to U. S. Air Forces in Europe and our NATO allies.
Surpassed in performance in the early 1950's by the Century Series fighters, the F-86 has long been retired from the USAF operational inventory. A number are still in use as target drones and for various flight-test purposes, and at least one manufacturer uses an F-86 as a chase plane.
Old 12-17-2014, 01:08 AM
Bobdaeronort
Bobdaeronort
The "FIVE EASY PIECE" North American F-86 SABRE is all ready for her Maiden Flight.
49" long, 50" KFm4 wing-span, 30oz. on the flight-line.
Powered by a Grayson Hobby SMJv2 spinning a 7x5 prop with a 50A ESC, and a three channel set-up: ailerons and flying elevator.
Chellie - If you catch a red-eye tonight you'll be here in time for the maiden.
Name:	5EZP Sabre@10.JPG
ID:	178836   Click image for larger version
Name:	5EZP Sabre @ 11H.JPG
Old 12-17-2014, 11:42 PM
Bobdaeronort
Bobdaeronort
Sabre Maiden Flight
https://www.youtube.com/watch?v=X1HgFiJqcfc
Old 12-18-2014, 12:23 AM
Scha-weet ! Bob, did you ever consider closing up the fuse and dropping in a 70mm or 90mm edf with a high blade count?
Sure looks good !
-Hawk
Old 12-18-2014, 02:31 AM
Bobdaeronort
Bobdaeronort
Sure looks good !
-Hawk
Thanks.
I have a 70mm but it only has a 5 blade fan.
I think the prop is not getting enough air.
Old 12-18-2014, 07:11 AM
Good Job
Old 12-18-2014, 01:11 PM
Bobdaeronort
Bobdaeronort
Good Job
Sorry you missed flying the maiden flight again.
I'm just a maiden flight hog.
Old 12-21-2014, 05:00 AM
Bobdaeronort
Bobdaeronort
I crashed it on it's third flight. The rear fuse twists more than Chubby Checker. I couldn't correct it with all the aileron throw full right and put it in hard on the left side.
I'm working on improvements like repositioning the motor aft and a new version of the internal fuse which will help grab more dorsal air for the air-starved prop and make the external rear fuse sturdier too which will hopefully arrest the twisting.
My A4E Skyhawk and Aero L-39 Albatros have some twisting of the rear fuse under load but not like the F-86 whose rear fuse is about 50% longer.
This bird is pushing 32oz. too so I may need to look designing at a smaller 70mm 4S EDF version too.
https://www.youtube.com/watch?v=kLmkky577Rs
Old 02-04-2015, 03:44 AM
Bobdaeronort
Bobdaeronort
Just rough-out my new and improved (and down-sized) F-86 SABRE.
She's now just 34" long with a 33" wingspan. Light enough I think for a GH MJv3 on 6x4 to power her or even a Detrum 64mm EDF. Here she sits with her contemporaries the F4D Skyray, F9F Panther, and the F-101 VooDoo.
Name:	Quintet F4D F-86 F9F F-101.JPG
ID:	179490   Click image for larger version
Name:	Quintet F-101 F9F F-86 F4D.JPG
Old 02-05-2015, 03:28 AM
Bobdaeronort
Bobdaeronort
The "5EZP" F-86 SABRE II all glued together and getting her gizmos.
She is 34" long with a 33" wingspan ( this makes her about 20" shorter than my first SABRE) and is powered by Grayson Hobby's Micro-Jet motor with a 6x4 prop and 20A ESC and weighs 17.5 ounces with a 1350mah 3S Li-Po. Her flight controls consist of a TP MG91R elevator servo and two Detrum servos for the ailerons.
She is constructed with an inner and outer fuse to allow air from the nose intake to flow to the prop. The inner fuse extends past the prop and into the tail section to add strength and route air from the dorsal side down to the prop. The inner fuse is constructed to hold the RX and Li-Po and is accessed through the hinged canopy. She has one 24" x 5.3 mm Carbon Rod in her Kline-Fogleman KFm4 wings.
Name:	%225EZP%22 SABRE II @11.JPG
ID:	179498   Click image for larger version
Name:	%225EZP%22 SABRE II Ventral.JPG
Old 02-06-2015, 03:04 AM
Bobdaeronort
Bobdaeronort
Sabre II maiden flight
https://www.youtube.com/watch?v=zdwPb7BlU70
Old 02-07-2015, 12:35 AM
Bobdaeronort
Bobdaeronort
Sabre flight with a motor upgrade - Grayson Hobby's Super-Mega-Jet with 6x5.5 prop.
https://www.youtube.com/watch?v=sbL6xnfE37M
Old 02-08-2015, 05:11 AM
Bobdaeronort
Bobdaeronort
Sabre flies in the wind
https://www.youtube.com/watch?v=vQW0OVy1Qn8
Old 02-11-2015, 04:41 AM
Bobdaeronort
Bobdaeronort
Multiple unceremonious contacts with the ground today took their toll on the SABRE.
Video coming soon.
I've already begun a new one with improvements. Still debating with my self on whether to go 70MMEDF with the new one. Leaning towards doing another prop version first. Or maybe I will do the EDF version.
Here's the video
https://www.youtube.com/watch?v=70O3JoOHDwQ
Old 08-25-2018, 07:27 PM
Bobdaeronort
Bobdaeronort
Now with the MiG -17 sorted out I'm taking the L.L.'s and applying them to the "5EZP" F-86 SABRE.
My version three SABRE is bigger than #2 (and smaller than #1 and) being 39" long with a 38.6" KFm4 wing-span ( so she is five inches longer and wider then the MiG) and like the Mig about 1/12th scale.
She will have dorsal intake patterned after the MiG-17 and flying "elevator-on-a-stick" and be powered by a SMJv2 "Prop-inna-box".
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 08-27-2018, 03:04 AM
Bobdaeronort
Bobdaeronort
More work.
Kline airfoils are on and the elevators just taped on now.
Motor and ESC are installed. The dorsal intake is done. the canopy foil is on and the canopy hatch is cut in and the magnetic catch installed.
Here the 1/12th Sabre and Fresco "Fly" side by side on their dowel stands.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 10-06-2019, 08:28 PM
Bobdaeronort
Bobdaeronort
Old 10-06-2019, 08:32 PM
Bobdaeronort
Bobdaeronort
Quick Reply: "5ezp" north american f-86 sabre
Page generated in 0.15355 seconds with 48 queries
