Did You Know? Wattflyer how too's and features articles.
How to add an Avatar
Old 01-05-2006, 05:04 PM
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
Default How to add an Avatar
To create an avatar one needs to have the picture saved in a file or the URL to that photo. The file limitations are 80x80 or 9.6kb (whichever is less)
To add that file as your avatar simply click on the link called "My Wattflyer" at the top of every page (see step 1 image). That takes you to your User Control Panel. On the left are a list of things to edit. One of them is "Edit Avatar" under Settings & Options. Click on that link. (see step 2 image)
From here it should be fairly self explanatory. But you basically select the custom avatar option and tell the site the URL of your avatar or, if you have it stored in a file on your computer, tell it where the file is. The browse button makes this very easy. Once that is done, you have your avatar. (see step 3 image)
If the avatar is stored on a server, then enter the entire URL in the upper box (must be formatted as http://www. ) If the URL address ever changes, then your avatar will be lost unless you update the address.
For visual instructions, please click on the photos.
ID:	5539 Click image for larger version
ID:	5540 Click image for larger version
Mike Parsons is offline
Off Topic Chit Chat
92
08-09-2015 06:24 PM
HeliG
Test Posting Forum
03-26-2008 10:06 PM
747
Support & Suggestions
10-27-2007 08:19 PM
bsoder
12
08-16-2007 06:15 PM
Quick Reply: How to add an Avatar
Page generated in 0.09829 seconds with 14 queries
