Peter Rake Heinkel He-51 prototype maidened and video. - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-30-2012, 05:24 AM
trumps1
Default Peter Rake Heinkel He-51 prototype maidened and video.
hiya guys,
been slowly plodding away with my Heinkel He.51 prototype that Peter kindly drew up for me, and Charlie at Manzano's beautifully cut. the plane has a 54" wingspan and should come in at about 5 1/2 lb. when it is all done and dusted Charlie will add it to his inventory. there is a build log over at RCG
http://www.rcgroups.com/forums/showthread.php?t=1664316
Craig
ID:	162243   Click image for larger version
trumps1 is offline
Old 08-30-2012, 07:00 AM
Looks beautiful! I'm so jealous of you guys who have the talent and patience for this kind of building. You're no longer limited to what they put out for ARFs.
Old 08-30-2012, 10:52 PM
Bill G
Super Contrubutor
Bill G's Avatar
That's the easy route. Like the Ansaldo, I beat Peter to them with scratch builds. Seriously, the HE51 was a lot of work as a scratch build. So was the Ansaldo. Nice to see Manzano having kits for folks to build these planes from.
Stop by more often Trumps. Those who got the JTGboot don't go there much. I have a nice scratch build going on here now.
I imagine you're doing the #7 scheme?
I did #2, since I had nice decals on hand.
Bill G is offline
Old 08-30-2012, 11:28 PM
trumps1
Yeah, will probably do 7, it will be a nice easy stencil to cut, just about lost my mind with the stuff doing my Holtzem schemed Pfalz a couple of years back and haven't touched the stuff since! Got a nice rare WWI project to build after this one, was contacted by the designer a couple of weeks back to see if I wanted a crack at it, plan looks very nice!
Craig
PS, nice job by the way, what method did you use for you exhaust Stubbs, the look great, I still have not gotten around to make mine, will probably make a cople of masters and just vac form them I guess.
trumps1 is offline
Old 08-31-2012, 11:04 AM
Bill G
Super Contrubutor
Bill G's Avatar
Craig
PS, nice job by the way, what method did you use for you exhaust Stubbs, the look great, I still have not gotten around to make mine, will probably make a couple of masters and just vac form them I guess.
The exhaust manifolds were a real pain!
I heat formed them from plastic tubing, making the 90 degree bend and the flare and the end as close as possible. Of course that wasn't very close, so I built them up with thick CA/activator, hand sanding all 12 of them to shape.
It probably would be a good idea to make them with something like resin, molded in halves and then glued together. At least that way, you would only have a center seam to sand a bit, after gluing them together.
BTW, I just saw your thread at the other place, and Peter mentioned that you need a 1/8 scale pilot. I have the perfect pilot for you: Peter Rake himself. I think he looks pretty close, and it was a good bit of work, reshaping the head to look like Peter.
Name:	Peter Rake_6.jpg
ID:	162297   Click image for larger version
Name:	Peter Rake_7.jpg
Bill G is offline
Old 10-07-2012, 04:58 PM
trumps1
slowly getting there, quite a few little details to go though like basic cockpit, pilot, radiator core and rigging. as we all know its the little bits and bobs that take the most time still need to do some power tests to decide on a suitable pack, i am thinking that 3S3300 should be in the ballpark, but want to test it first.
Craig
ID:	163206   Click image for larger version
ID:	163207   Click image for larger version
ID:	163208   Click image for larger version
trumps1 is offline
Old 10-07-2012, 05:54 PM
fantastic work, almost makes me want to dust the old building board off.
Old 10-07-2012, 08:39 PM
earthsciteach
I'm blown away by the craftsmanship I see on this forum! Truly inspiring, trumps1. Thank you for sharing!
earthsciteach is offline
Old 10-08-2012, 03:07 AM
Bill G
Super Contrubutor
Bill G's Avatar
Beautiful job Trumps. The exhaust manifolds made from molded halves worked out as well as could be imagined. I think we have two of the most accurate HE51 models out there now. You and Peter really got this one right. I came across many with that just didn't quite have the shape correct, when I was building this plane.
Bill G is offline
Old 10-08-2012, 06:26 AM
trumps1
Cheers all, Pete really did a cracking job of the design of this one, it is a good one to build! Greatful that he took it on being as it is not really his cup of tea era wise! With my fly in fly out work schedule it would have taken far too long for me to try and draw one up my self, wouldn't have been a patch on petes quality either!
Craig
trumps1 is offline
Old 10-25-2012, 02:15 AM
trumps1
Well, she is all done and dusted, maidened her the other day, she flys like a dream, even in our windy conditions, didn't even mind crosswind landings which are the norm at our club. came in at a slightly heavy 5.5lb RTF but such is life. got 3 flights in with no bad habbits to report!
Video is of the 2nd flight
http://youtu.be/cvyCnXC19JQ?hd=1
Craig
ID:	163725   Click image for larger version
ID:	163726   Click image for larger version
ID:	163727   Click image for larger version
ID:	163728   Click image for larger version
trumps1 is offline
scigs30
WWI Era
11
01-30-2015 04:37 PM
scigs30
05-21-2012 05:37 AM
scigs30
05-02-2012 10:08 PM
waynek
WWI Era
02-21-2011 03:12 AM
Quick Reply: Peter Rake Heinkel He-51 prototype maidened and video.
Page generated in 0.07888 seconds with 29 queries
