Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
Old 06-26-2017, 12:04 AM   #1
F22trainer
Default Guillows P-38
Guess I should start the build thread before I get too far. All the plumbing is in. I spent a bunch of time beefing up the tail assembly and the stabilizer had to be rebuilt as it has some ugly warps, twists and gaps. The wing tips will get cut off and replaced a carved solid balsa taper to make it easier to sheet. One of the next steps is putting her on a diet...hole punch for wing ribs and formers.
I know I posted up some photos in another thread, but figured this was the right place to continue. All up it is 14.6 oz now, sans batteries (380mA /7.4V). Not sure where the CG is right now, but have plenty of space (if that's really possible) in each fuselage near the CG point.
Now for the really clever stuff...I figured out how to use the scale cutouts in the cowl and fuse scoops to be functional for cooling. Each section can be removed with a few screws or nylon bolts, except the vert stabilizers. Once they're covered and epoxied - they will be permanently attached - rudders can be removed to separate fuse from tail. Though I don't plan on doing that on any regular basis.
F22trainer is offline
Old 06-26-2017, 12:42 AM   #2
F22trainer
Couple of more photos I don't think I posted.
Old 07-09-2017, 09:56 PM   #3
F22trainer
Default Update on progress
Balsa sheeting has begun. Did an engine run and servo test and everything checked good. Battery box fits nice just slightly behind CG point with easy access under 'supercharger' cover. Plank sheeting worked good on lower fuselage half.
Old 08-17-2017, 06:21 AM   #4
F22trainer
Busy with work so have not had much time with the hobby stuff. Got a few shots of the wing sheeting underway.
Old 08-30-2017, 03:43 AM   #5
F22trainer
Default Post balsa sheeting
Balsa covering nearly done, reassembly to check fit under way. I'll try to get a video of start up tomorrow.
Old 08-30-2017, 01:30 PM   #6
Stay Quiet
Stay Quiet's Avatar
Club: Campobello Flyers
Very nice work! The P-38 has always been one of my favorite WW2 planes.
Stay Quiet is offline
Old 09-02-2017, 04:39 AM   #7
F22trainer
Default ...and now the fun begins!
Started dialing in the tail feathers and got all controls working from radio. All smooth - did get some "chatter" from the aileron servo - any ideas or worries? One vertical stalizer was covered at the end of the day, but I will post up some pics after tomorrow when more is done.
Old 09-05-2017, 02:56 AM   #8
F22trainer
Default Covering process and progress!
Tedious...
Old 09-11-2017, 05:26 AM   #9
F22trainer
Fuselage sections covered.
Old 10-07-2017, 04:56 PM   #10
F22trainer
Default Update
Final assembly underway, those plastic pieces are actually fitting pretty good but a few got deformed over the years and seems the heat gun is an essential tool. Don't want to get crazy with the details until after the maiden flight...
Stay tuned -
Old 11-06-2017, 12:14 AM   #11
F22trainer
Maiden flight is coming soon. Now for the question, should I put a gyro in it? Since I will not be the one flying, I suppose it could be off for the first flight a get all the trims set up. I have a great 'instructor' and test pilot at the AMP's club here in Phoenix. My thumbs are getting back up to speed.
The Lightning is at the point where I want to fly it before I spend any more time on finishing. I did a start up and taxi and was impressed with the ground handling. Made some minor linkage adjustments and changed the rudder control cable to a solid wire. The single aileron servo was just not enough and shoe horned two metal gear servo in the wing. When I build the next one it will definitely get micro's in the wing. Now I found a new issue. Rapid movement of those ailerons causes brownouts - normal movement has now issue. I do not plan to do aerobatics with it so I can live with it if it would not be a safety issue.
Thoughts?
Old 11-06-2017, 01:43 PM   #12
Friends: (10)
Gyros are quite useful especially on smaller planes as they help smoothen the flight and make the plane less effected by wind gusts etc. Usually they don't really make the plane easier to fly as such, just smoother looking in flight. For the maiden you would want to either disable the gyros or at least have the gain set low. Too high gain can cause violent oscillations which is the last thing you need on a maiden.
Good luck, she looks great!
Old 11-25-2017, 01:54 AM   #13
F22trainer
Thanks JetPlaneFlyer,
Still making some tweaks and tests. Did do some taxi tests and got it tracking straight, even got up a little speed but backed off as she started to rotate - woah girl. Tweaks are kind of a pain, as I wind up having to remove the wing. Got one more to take out some elevator and get it centered. Hoping next weekend I can take two planes to the field.
I'll hold off on the gyro for now, but she is small and could probably use it later on. Kinda crowded in those little fuselages.
Guillows Stearman Bill G Scratch and Kit Built Aircraft 45 01-14-2017 04:08 PM
Guillows 24" Beaver Bill G Seaplanes E-Powered 8 08-14-2016 02:02 AM
3rd Times a Charm, Ain't No Chance of Being Tail Heavy, Guillows 16.5" FW190 Bill G Scratch and Kit Built Aircraft 17 03-23-2012 02:42 AM
38 inches yak 55 harrys 3D Flying 3 12-11-2010 11:26 AM
Page generated in 0.18262 seconds with 85 queries
