Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Vintage and old timer models
Old 06-14-2017, 01:31 AM   #1
F22trainer
Default MEN Trainer
Curious if anyone has recommendations for an under-camber wing covering? I have an old trainer 3- channel airplane I bought long ago...needs wing recovered. I tried Monokote, but just didn't work out to my liking and underside did not adhere well.
F22trainer is offline
Old 06-14-2017, 01:58 AM   #2
Might try using my trainer. Most MEN like it. I am sure Blair can iron out your rough spots.
dereckbc is offline
Old 06-14-2017, 02:49 AM   #3
Friends: (8)
I should start working on my MEN trainer, my wife started it many years ago but lost interest in modeling.
My old flying buddy built one in the 70"s he covered with monokote, but he used Balsarite on the bottom surfaces. It increases the bond.
He ironed the covering to the bottom of the spar then to the bottom of the ribs being careful to keep the covering smooth. When he shrunk the covering he did not touch the ribs or spar.
It takes time but it can work.
Silkspan or Silk might be a good choice also.
There used to be a material called Silron, it had Silk fibers running one direction and Rayon running the other. The Silk fibers shrink more than the Rayon (if I remember right) you wanted the fibers that shrank more running the length of the wing. It worked very well on wings like a Proctor Antic
Old 06-14-2017, 04:57 AM   #4
F22trainer
Iron on covering is definitely the wrong for this application...
Old 06-14-2017, 05:49 AM   #5
Friends: (8)
Should have told him before he did it successfully about 40 years ago.
Old 06-14-2017, 05:10 PM   #6
F22trainer
Not what I meant there ( referring to the model with the putter), but Sounds like that technique would work. My thinking was something like silkspan might lay in the arc better. I agree it is going to be an exercise in patience.
Old 06-26-2017, 12:28 AM   #7
F22trainer
Ok, so maybe it was a tease- bought this from Bob Rainey back in the 80's as my first RC. so I dug it out to get some pictures. The OS 20 will go to anew home. Hoping a Power 25 will do about the same job with a 9x6 prop.
I think I still have the old World Radio TX / RX...but that will yield to Spektrum.
As you can see, the wing covering needs some serious attention, but the fuse came out great.
By the way, does anyone have copies of the prints or perhaps some specs on thrust angles and CG location?
Old 06-26-2017, 07:48 AM   #8
Friends: (8)
I should have the plan, I'll look tomorrow
Old 06-26-2017, 08:12 AM   #9
F22trainer
That would be great. Hope you'll pick up yours and finish. I think they would be a blast to fly with electrics. Mine usually ran great for about 90 sec. and was then glider practice, getting it restarted was always a pain.
Old 06-26-2017, 10:22 PM   #10
Brner
AMA16634
Friends: (12)
Default CG
Here's a snippet from the plan showing the CG....HTH
Don
Brner is offline
Old 06-27-2017, 04:22 AM   #11
F22trainer
Don
Nice job - Thanks very much! Pretty much where I would have started at 75% chord.
Old 07-14-2017, 09:22 PM   #12
F22trainer
Don
Got a detail on engine / thrust angles?
Thanks. Been looking for a whole kit, but no luck yet. Ordering plans from AMA, but am ready to install engine.
Old 07-15-2017, 01:12 AM   #13
Brner
AMA16634
Friends: (12)
Here's a PDF showing down thrust, no side thrust shown that I can find. I put the angular measurement in there. Looks like a lot of down thrust but that's what it shows.
BTW, you can find the plans I have on this on the Outerzone site..
http://outerzone.co.uk/
Don
Brner is offline
Old 07-15-2017, 07:12 AM   #14
F22trainer
Don
I spent many search sessions looking for that - HUGE Thanks!
I plan to get the wing recovered this weekend.
Old 07-15-2017, 03:26 PM   #15
Not exactly a model. It is Blair O'Neal a LPGA Tour Player.
dereckbc is offline
Old 07-18-2017, 06:08 AM   #16
F22trainer
Got busy with the wing and a few other tasks.
Test fit of the Eflite Power 10 looks simple enough should not have to get fancy with a motor mount. Contemplating a simple cowl.
Rudder and elevator install with new push rods and servos was smooth. Lots of room compared to that P38 (which is moving along nicely with the sheeting).
Picked up Spektrum AR400 receiver which I think will get lost in that huge box for the gas tank I removed.
Got the wing stripped and nearly cleaned up and ready the cover. It does not balance at all, due to some obvious repairs with structure on one side. Didn't know about that but it looks straight and sturdy.
I think I will go with white iron on covering - any recommendations on what to avoid? I appreciate the suggestions on undercamber wing coverage. Guess it will depend on what LHS has in stock.
Will pick that up along with a new set of gear and lite wheels tomorrow on the way home from work.
Enjoy hearing your ideas - Thanx guys!
Old 07-30-2017, 04:40 AM   #17
F22trainer
Default And now the B side...
Got engine installed and started the new covering. Undercamber wing was a challenge and took time - used your suggestions, but did try the heat gun with no problems. Engine mount was 1/4" Sintra with vent holes.
Old 08-17-2017, 06:26 AM   #18
F22trainer
Now with any luck, I may get the landing gear bent and axles pressed, etc. on my next day off...whenever that is. LHS had nothing in the gear selection so it's a DIY. Almost ready for a trip to the field.
Old 08-17-2017, 06:26 PM   #19
F22trainer
Default Need help here...
Anyone know the wheel / strut measurements on these?
I'd like to use them on the MEN, and are they aluminum struts? HZ has no info except they are for the eFlite Cessna CZ - 150.
Would be perfect if #'s work!
https://www.hobbyzone.com/EFL1408.html
Old 08-18-2017, 05:37 AM   #20
Brner
AMA16634
Friends: (12)
You did a great job on that wing covering....nice work all around!
Don
Brner is offline
Old 08-18-2017, 06:10 AM   #21
F22trainer
Don
Big Thanks! The stripes are temporary/test - think I will go with a navy blue instead.
Old 11-04-2017, 10:57 PM   #22
F22trainer
Default Restomod maiden flight
Had the club instructor help me with the maiden first flight, and I got a few pics of the landing. Was a little squirrelly on the first T/O, and elevator trim was maxed out and was still climbing. Rudder needed a little more left as well. Made the adjustments and got 2 more flights. Very crisp handling in the air, but still squirrelly on takeoff, mostly due to 'ailerrudder' controls.
Old 11-24-2017, 11:18 PM   #23
F22trainer
Default New gear
Got the new landing gear and wheels on, removed the tail feathers and replace tail wheel bracket. Covering was poor so just decided to go all out with new colors and fillets too. Found a lighter tail wheel, and I guess the lighter landing gear offset the tailwheel - no change in nose weight. Weighs 4.4 lbs AUW...about 2 times what I figured, but she flew well on the last flight. I hope to try some different props next flights- got a 9x6 on it now. Picked up a 9x7 and 9x8. It flew well at half throttle. Had to add 12 oz. in the nose to balance, so that was part of the weight increase.
BH Star Trainer RKEstes Beginners 13 03-17-2013 03:58 PM
What is the Best EPP Trainer BlakeL Foamies 17 02-11-2013 02:46 PM
Want to build a trainer kit and electrify it. Droiddr Beginners 12 01-05-2013 04:55 AM
What are your CLUB TRAINER airplanes? Saddlebum General Electric Discussions 8 01-04-2011 11:52 PM
Gift ideas for men Don Sims Humor 0 12-22-2010 02:09 AM
Page generated in 0.17016 seconds with 87 queries
