Great Planes F-glass SeaWind Conversion
I have a Great Planes fibreglass Fuse SeaWind that I want to convert from the OS 91 FS to Electric power.
I am having trouble finding the right motor because you can not use a large diameter prop (it will hit the cocpit).
Has anyone done this? What motor and prop combo should I use?
I have a 50 65 380kv Turnigy Aerodrive Motor, do you think it would work with a 15" 3 blade?
Any help would be appreciated.
Bill
Bill
To use a smaller prop you need a higher KV motor to get the same thrust or you will be running at WOT most of the time.
Why do you think a 15" prop wouldn't work? Use a higher pitch to increase the watts. I haven't put a pencil to it, but it would look to me like it would work fine. I'll respond later when I have the time to figure it. There are on line power calculators you could use. Don't have a link off hand.
Your going to need to put at least 1000-1500 watts into that bird to get decent performance Id think, so you need a hefty motor.
Ive been running into the same thing on my Polaris build.
Which motor you need and which kV depends on 2 things - max prop clearance and which batteries your going to use.
If your running enough voltage, that motor might work - IF it can handle the watts. The rateings on those cheep motors are usually exagerated a lot.
Seawinds are relatively heavy planes with moderately hi wing loadings. Your going to be 10-12 pounds at least, so that 1000 watts will be an absolute minimum Id think. 1500-2000 would be better.
Good luck!
Good luck!
stefanv
21
04-17-2011 09:53 PM
tkollen
09-18-2008 11:15 PM
rongreg13
10-27-2007 02:04 PM
manga
12
11-21-2005 02:02 AM
