Nostalgia-Mambo with Tobe Galloping Ghost
Old 10-24-2016, 10:21 PM
E-Challenged
E-Challenged's Avatar
Default Nostalgia-Mambo with Tobe Galloping Ghost
Just want to share. I obtained a Tobe GG motor driven actuator that works with ANY modern proportional RC transmitter and receiver to give you flapping proportional rudder and elevator control plus normal throttle control via the speed control when using electric power. The actuator with attached "recoder" plugs into the aileron and elevator channels of any modern receiver on any frequency with no modifications to transmitter or receiver.
Contact Jay Mendoza , Mission Viejo, CA for info and pricing on the Tobe actuator:
[email protected]
I downloaded the plans for a 1960's 48" wingspan Mambo trainer from Outerzone to a flashdrive and took it to a FedEx Central office where they printed full size plan and pattern sheets plus the original Mambo wing logo for $16. I found a good local hobby shop, Remote Control Hobbies, in Orange, CA where they keep a good stock of sheet balsa, ply and basswood
as well as bagged accessory items and wheels.(About $76)
I'm ready to start cutting out ribs, formers and balsa sheet slab fuselage parts. Covering will be translucent red for wings and lifting stab and yellow for he fat fuselage. Graphics will be by Callie Graphics.
Nostalgia doesn't come cheap but should be a lot of fun.
E-Challenged is offline
Old 11-06-2018, 05:55 PM
E-Challenged
Update
The little Tobe GG actuator did not have enough power to control my full size Mambo, better suited to smaller Mini Mambo and other smaller lighter models. I installed two 9 gm servos and the model is now fully controllable. Watch Otto Diffenbach's videos on You Tube.
Old 12-30-2018, 02:31 AM
Abuelo
Abuelo's Avatar
Default Galloping Ghost
Originally Posted by E-Challenged View Post
Update
Thanks for the update. I also have the Tobe GG actuator and I'm debating on either the Half Tone by Dave Platt or the RCM 1/2A Basic Trainer by Dick Tichenor. Both would have been .049 powered and rudder and elevator back when designed. I have the plans for each and probably most of the wood and covering, just need to get a project out of the way and flying before deciding.
I'll post once I get to building. I really wanted a GG setup back in the 1960s but didn't have the money. Now is the time to relive my youth the way I wanted to.
Abuelo is offline
Page generated in 0.10058 seconds with 13 queries
