Will it Fly?
Ok guys its opinion time. This is based on the logo design used by the company I work for. I thought it would be a flyable shape. The undersized elevator and short tail has me wondering. Should I go with ailerons and elevator or try it with elevons and maybe slave the elevator? Anyone have a clue where the CG should be?
Should fly fine. Flying stab would work better. May be able to cheat a bit and enlarge the stab but I don't think it would be necessary. What does the rudder look like? Make sure you make it big enough or you may get into a dutch roll problem with such a short tail moment arm. Make a 9 or 12 in. balsa or depron glider with the same planform to find the CG. Put a bit of up elevator in it and add nose weight till you get a fast flat glide. CG will be in the same place on a bigger one. Hope this helps. Ain't experimenting fun
Hi Gord,
Thanks for the reply. The vertical fin is about the same size as the under sized stab. Maybe the flat Fuse side will hold its own. Got the radio installed, the CG is about a inch behind the 90 degree area of the leading edge which might be nose heavy but its a start. It has enough power on 7.2 V to more than support (hover) its own weight. Weather permiting thursday might be the day. If it lives I'll work out the bugs and the next one will get more attention and the company Logo. That should trip out the guys at work.
good luck on your plane let us know how it flys.
Originally Posted by Foamiesrfun
hey looks like a nice plane should fly good. I like your username also.I dont think most will get the full effect of it,Guess you been flying RC for a long time as my fatrher has he started in the 60s.hes told me all about the old systems
It flew, it has more thrust pull than I expected and needs lotsa right thrust. I flew it on aileron and elevator first so all the work my left thumb was doing trying to feed in right rudder was a bit wasted. Reflexes are great but they need servos and control sufaces.
Thanks for the CG info fdix!
I'd take the motor and battery out, use weights to find a starting CG and throw it like a chuck glider. Move the CG back or forward until you find the one that will give you a nice glide. If it gets a little bent, just cut another "pretty" one out and mount the motor and go fly.
John
John
The right thrust was the ticket. Flys stright and rolls like a ball. It flys like its tail heavy until you get out of the power. Man, this Fan Fold holds up good........so far its a better logo than a model
. The CG program is hard to use on a shape like this. Jonnyjetprop and flypaper 2 CG test may be over due.....the airframe is showing a little abuse
Galloping Ghost:
Went through the GG phase too. Last one I had was the Rand Actuator. We'll let the newbies figure out how they got rudder, elevator, and throttle out of one servo
Went to reeds after that.
Originally Posted by flypaper 2
Galloping Ghost:
Do you remimber the Ace Pulse Proportional magnetic actuators? We need to post a photo of a reeds TX! Now thats something for a newbie to ponder.
I still have a F&M Matador reed trans. and a E. D. single channel trans. Funny part is, the single channel trans. is bigger than the F&M and both are bigger than than the ones we have now. Some of the planes were very small for their age. Built a 12 in span model with an Otarion rcvr. The rcvr was a kit you had to put together. Was about the size of a postage stamp. No I.C.s back then. Actuator was a relay with a brass arm soldered to the movable part. Power was a Cox .010. No throttle control, only rudder. Flew well. They were the do it yourself days
Hey Galloping Gost,
Your user name and post's bring back memories of the early 60's for me.
I flew the Galloping Gost system or pulse. I had a nice little Bipe with the wagging rudder and elevator.
Originally Posted by Pyrock
Do you have any vids? Looks like a nice design. Also, have you tried to use a pusher design for it? Your front end looks a lot like my F22 and it's a pusher on elevons.
Originally Posted by Crashalott
Hey Galloping Gost,
protojet1.pdfHere a concept pusher foamie. Drew this up and started a build. I will attach some construction pictures later this week.
Well here are the build photos of day 3 for this project. I made some headway in putting on the intakes and motor mount. I am working on the details of a removable rear cover to gain access to the radio gear. I haven't decided on what to call this thing
(any suggestions) if it flies like i predict, it will scare the *#$& out of me. So maybe i'll call it the scat fighter. Suggestions Please on a name and markings!!
