C rating - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
C rating
Old 12-23-2010, 11:35 AM
shaf
Default C rating
I have two batteries, one with a 15c rating and the other at 30c. What exactly is the c rating and can I use them interchangably? Specs are otherwise the same.
Shaf
shaf is offline
Old 12-23-2010, 11:47 AM
Shaf
The "C" rating is the rate at which you can safely draw amps out of them. The formula is MAh x C/1000 = amps.
So if you have a 2100 mah 15c battery it is
2100 x 15 = 315000/1000 = 31.5 amps
for a 30c it would be
2100 x 30 = 63000/1000 = 63 amps
Old 12-23-2010, 12:49 PM
cliffh
...and yes you can use them interchangably. Depending on age, useage and other factors, you may see a slightly larger amp draw and more power with the 30C battery as the voltage will likely drop less under load.
Cliff
cliffh is offline
Old 12-23-2010, 01:00 PM
Well you can use them interchangeably if the max amp draw is under 31.5... if it is above that then the 15c battery won't be up to the task.
Old 12-23-2010, 02:59 PM
cliffh
Good catch. I never use my batteries near the max ratings, so I didn't think to mention that.
Cliff
cliffh is offline
Old 12-23-2010, 03:02 PM
That's a good thing to do, Always give yourself some leeway amp wise. If you are running a battery at it's maximum c rating all the time it's like driving you car everywhere with the gas mashed all the way to the floor all the time. Not too good for it.
Jzone99
01-09-2011 08:16 PM
av8djc
75
12-14-2010 01:17 AM
offtom
14
12-10-2010 05:21 AM
Quick Reply: C rating
Page generated in 0.09099 seconds with 13 queries
