Adaggio my new glider - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-27-2006, 05:03 PM
cebola
cebola's Avatar
Default Adaggio my new glider
Adaggio my own design concept
The basic concept of the Adaggio is to be a simple and easy model to construct.
A central panel of long wing of 48"and tips that can be connected using dihedral or aileron.
A double a Komodo engine, modified, turning a 9X45 aeronaut prop.
Adaggio does not use spoilers or flaps, on the contrary, uses reversion in the ESC.
It goes up very well and in a strong thermal , with engine in reverse it goes down fast and without bigger complications
Technicall data
Wing span 85"
Wing chord chord 11"
Wing chord at tips 7"
Complete Weight with batteries 16/18oz
Airfoil S4083
Length 50"
I hope you like it.
Adaggio has a fantastic glide ratio, and it's a very easy to fly model.
In fact behaves like a Nordic A2 free flight model.
Cebola
Brazil
ID:	15833   Click image for larger version
ID:	15834   Click image for larger version
ID:	15835   Click image for larger version
ID:	15836   Click image for larger version
ID:	15838   Click image for larger version
ID:	15839   Click image for larger version
ID:	15840   Click image for larger version
ID:	15841   Click image for larger version
cebola is offline
Old 09-02-2006, 04:33 AM
TeslaWinger
Nice design, Cebola! Very light for a plane of this size! No wonder it flies like a Nordic!
The use of REVERSE thrust is interesting! I have been wanting to avoid adding spoilers which can add drag even closed. None of my ESCs have reverse but I have experimented with reduced power - and overflying the prop- for glideslope control- but reverse would sure slam on the brakes!
One thing I noticed was the adverse yaw it adds when turning while powered back and overflying the thrust since so much drag is forward!
Straight approaches are simple- but I cut power for low turns to avoid yaw control problems with the prop in drag mode!
One of my first serious gliders was a Nordic type tow glider- and this glider is just as beautiful!
Good work!
TW
TeslaWinger is offline
Old 09-02-2006, 05:36 AM
cebola
cebola's Avatar
Good work!
TW
TeslaWinger
I practice free flight from many years, in fact I love the Nordic A2, Adaggio is a copy of one of those wonderfull models, but bigger.
Reverse ESC works nicely, but on a straight fly, I dont try to make turns on reverse mode.
Mainly because I never need it, the sink ratio in enough to get rid of strong thermals.
Regard's
Cebola
Brazil
cebola is offline
Old 09-15-2006, 03:47 AM
cebola
cebola's Avatar
Just in case...
This is Adaggio overall lay out
Cebola
Brazil
cebola is offline
Old 09-15-2006, 06:15 PM
tillmas
The Quack
tillmas's Avatar
Beautiful model, and it is really great to see people thinking about innovative ways to do things. I wonder if a folding, reversible pitch prop is all that far off...
One question: what made you choose the S4083 airfoil?
tillmas is offline
Old 09-15-2006, 11:54 PM
cebola
cebola's Avatar
Hello Tillmas
The reverse ESC is a very old thing, only makes the engine works on a reverse mode, the old RC cars use for many years.
On Adaggio works like a big bkake, but no disturbing the wing structure because of gaps, warps, and weekness.
It works very well, and cause a disc on prop whit front trust.
The S4083, is a real glider airfoil, glides well, whit a very good glide ratio, and low sink ratio.
But I believe that airfoil for gliders is a very personal thing, and seelig airfoils works well.
Cebola
Brazil
cebola is offline
jksecunda
12-01-2008 10:21 PM
BUCKSHOT
11-01-2008 10:28 AM
crabby
09-12-2008 03:16 PM
zerts
07-16-2008 02:05 AM
stinkweed007
11-04-2007 01:17 AM
Quick Reply: Adaggio my new glider
Page generated in 0.06193 seconds with 25 queries
