T-bird free flight conversion - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 03-20-2011, 08:41 PM
F7U
Default T-bird free flight conversion
The concept was to build an old-school free flight and avoid the issues to fuel-drenching and chasing around for miles. The T-bird is an old favorite, known for stability and good performance. Also, my dad built one when I was about 7 years old and that plane really impressed me, as went OOS on its first flight.
Project started with a laser-cut semi-kit from BJModels.....great cut quality and good balsa. The motor is a 3000KV brushless, allowing use of a "scale" 6" prop (low drag at glide). Battery is a 2S, 370mA. Control is throttle and rudder, no elevator. Airframe modifications limited to stronger center wing joint (known weakness with the T-birds), widened pylon (to fit the battery), and modern covering (GOLDBERG lite). Measured thrust, static, is 4.5oz. Thus, strong climb but limited duration. Fuselage coated with a couple light sprays of laquer, with sanding in between coats. Weight, RTF, is 5.7 oz (the plan lists 5oz as free-flight weight) Suppose the savings in weight from .049, timer and two coats of dope almost made up for adding the micro rc unit and the battery. CG came out just right (lucky!).
Flown this plane twice. From glide test, added a .06" shim under the LE of the stab, as showed a slight stall. Low-power flight was a non-event....very stable (but still tried to give it elevator....old habit). Full-power climb really surprised me. Very quick acceleration and near-vertical. This plane really knows how to climb. Only correction from 1st flight was to add more movement to the rudder, as wanted the ability to spin it down in case of a thermal. So, flight plan is a gentle launch with about 1/4 throttle, roll on to full and it seems to know what to do. Only remaining trim issue is that after about 5 seconds the plane is almost vertical and may start turning on its back. Adding rudder just causes a wing-over. Suspect that is why the plans show the stab should be at a tilt? That may result in the spiral climb that the free-flighters trim to. For now, I can just roll the throttle off and the plane transitions well to a glide. Then just trim for a nice circle.
No in-fligh fotos yet, but during glide, there is plenty of time to set the transmitter down, get a sip of water and retireve the camera. Battery capacity good for 3 to 4 zooms to high altitude.
Would appreciate any input from some free-flighters about trimming for a spiral climb. That would really complete the project.
ID:	145073   Click image for larger version
ID:	145074   Click image for larger version
ID:	145075   Click image for larger version
F7U is offline
Old 03-20-2011, 11:15 PM
Forge
Forge's Avatar
F7U,
Really nice. I especially like the transparent yellow covering...very cool.
And I like the idea of being able to sip a cocktail while flying.
Good flying.
Forge
ps. what is the wing span on the plane?
Forge is offline
Old 03-20-2011, 11:36 PM
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
Hi
Outstanding
Pleased to meet you
Thats quite a wonderful job you have done
Shes absolutely gorgeous
Some tips for trimming F/F aircraft
http://www.rc-airplane-advisor.com/r...ee-flight.html
Take care
Yours Hank
kenchiroalpha is offline
Old 03-21-2011, 12:04 AM
F7U
Post
Hank,
That is a great website you provided. Great info.
Appears "high thrust contest-type" free flights have some special trim requirements (been researching this subject on this very rainy Sunday)
Appears the climb requires a 3 degree left thrust to the motor, coupled with a washout on the right, outer wing panel. Supposed to give a right, climbing spiral. However, a thrust of 1:1 does not really qualify as "high thrust". Some hot 1/2As privide 12oz of thrust.
Free flighters are the real masters of model planes!
Interesting you mentioned the Pilatus Porter. I build a scratch one from 2X plans for a rubber-powered. Very light, 50" span. Really like both the real plane and the model.
F7U is offline
Old 03-21-2011, 12:10 AM
kenchiroalpha
Talking
Originally Posted by F7U View Post
Hank,
Hi
Happy to be of help
My dad and i used to build and fly F/F aircraft, its what got me into the hobby in the first place
Still have many F/F's and they get much use with more to come in the future
Heres another wonderful site i think you may find of interest
http://www.ffscale.co.uk/
Take care
Yours Hank
Old 03-29-2011, 06:18 AM
F7U
Thermal Flight!
Took the T-bird out Sunday morning, after making some recommended trim adjustments: left and down thrust and washout in the right, outer wing panel.
Under full throttle, makes a nice, steep spiral climb. Can easily adjust the rate of spiral with a bit of rudder trim.
Credit for the trim tips from a real free-flighter and some internet research.
On fourth buzz up to altitude, the ESC cutoff hit, so only got about 2/3s the altitude. This time, the plane seemed a bit unsettled on the glide. Then realized it was climbing. Wow, was really neat watching it "glide" back up to high altitude.
The entire flight control consisted of occasional rudder trims. Felt more like a spectator than a pilot. Even got out of the habit of giving elevator inputs. These old free-lights are aerodynamic oddities, but they sure are stable.
Anyway, a great diversion from my more typical park fliers.
Try one!
CORRECTION: Plans and laser-cut semi-kit form BH Plans. Check out the great selection.
F7U is offline
All American
08-31-2011 08:21 PM
Saddlebum
07-09-2011 11:56 PM
CPomeroy
02-12-2011 08:45 AM
alex.guzun
Vintage and old timer models
03-19-2010 10:14 AM
Quick Reply: T-bird free flight conversion
Page generated in 0.05940 seconds with 18 queries
