PBY conversion finished - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 03-18-2009, 09:59 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Default PBY conversion finished
Finally completed the conversion from .40 engines to .35 electric.
Plane: Scratch built from plans enlarged 6x by Ray Tomczyk
Conversion: Don Jiskra
Motors: 2- Turnigy 4230-1050
Batteries: 2- Zippy 4s 2200 mah lipos
ESC: 2- Hextronic 80 amp
Props: MAS 9x7 3 blade
Antenna: Deans Micro
Wingspan 75"
Weight 7 to 8 lbs
Maiden Flight: April 17th
ID:	96661   Click image for larger version
donjiskra is offline
Old 03-19-2009, 12:12 PM
Maine Flyer
Maine Flyer's Avatar
Hi Don,
Looking nice.
How much power are you getting from this setup?
Joe
Maine Flyer is offline
Old 03-19-2009, 12:56 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Thanks Joe, it was scratch built by Ray Tomczyk. He did a beautiful job.
I only did the electric conversion. Which necessitated enclosing the cowls, and installing the batttery heat exhaust vents (the black area in the nacelles).
Ray flew it with twin .40 engines, He said it was way too fast for him and thought the .35 size electric motors would be fine.
I checked one motor running with my Astro Wattmeter at full throttle, it indicated 365 watts.
I'm looking forward to the April 17th maiden flight, which I will video tape and post.
Regards,
Don
Old 03-19-2009, 04:20 PM
gfdengine204
gfdengine204's Avatar
Don,
Looking forward to your flight report and video(s).
gfdengine204 is offline
Old 03-19-2009, 05:02 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Thanks Kevin,
Me too!!!!!!!!!!
Old 05-21-2009, 07:17 PM
Fviking
Fviking's Avatar
Smile ROW or not
Well it is the middle of May what happened ??
Did it fly and where is the Vidio ?
Viking
Fviking is offline
Old 05-21-2009, 07:31 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Fviking and all those who have been following the conversion.
It had it's maiden flight May 6th and performed way better than I had expected. Plenty of power, as you will see in this video:
[media]http://www.youtube.com/watch?v=iJoDibl7Y0w[/media]
Thanks for checking,
Don
Old 10-30-2010, 02:06 PM
Bill G
Super Contrubutor
Bill G's Avatar
Don,
You and your buddy, and of course the PBY have made it into the public photo section of AMA's magazine.
Bill G is offline
Old 11-20-2010, 09:40 PM
PhantomSC
That looks awesome! I've always wanted a PBY.
PhantomSC is offline
Old 11-20-2010, 10:08 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
THANKS, the PBY is indeed an awesome model.
Here's a review of one that is available and is a GREAT flyer:
http://www.rcgroups.com/forums/showthread.php?t=674400
Old 11-21-2010, 02:05 PM
tampaflyer
to the skies of tampa
tampaflyer's Avatar
looks great, know the feeling...
60 size ..electricified...
ID:	139256   Click image for larger version
tampaflyer is offline
Old 11-21-2010, 02:21 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
WOW, not that is AWESOME, well done, she is a beauty.
Old 11-22-2010, 07:17 PM
eflight-ray
eflight-ray's Avatar
Nice one Don, I flew an electric powered Cat some many years ago, (late 80's). It was actually built from a plan for an IC powered control line model, and flew great from a hand launch.
But then someone convinced me that I should try it from water.
It was filmed, (still got it on standard 8mm cine somewhere), and could have been set to music, Swan Lake, at it did pirouette after pirouette.
Was on the secend set of batteries before it actually got airborne. My Cat had a problem with the tip floats 'digging in', I think your's may have a slight problem as well. Cured it by angeling the float nose up a bit more, and reshaping the underside to ensure it always pops up once moving forwards.
Similar problem has occurred recently with my Sunderland. Once a float touched the water in a slight turn it wanted to submarine dragging the model around even tighter.
Cured it again by raising the float nose. The rear end of the float actually touches the water first now and very little drag is caused.
I know it doesn't make them scale any more, but it sure does help when taxiing and on the take off run.
Hope you have many more great flights from her.
When ever I see those clear plastic moldings around the bigger Easter eggs, I instantly think, 'cupola windows for a another Cat ?'.
Ray.
ID:	139367   Click image for larger version
eflight-ray is offline
Old 11-26-2010, 06:28 PM
Bill G
Super Contrubutor
Bill G's Avatar
Here you go Don and all. You made the public photo section in Nov 2010 AMA mag. It may be a bit easier to do, if they featured nice planes like yours, versus a bunch of lousy ARFs and RTFs, that are already seen in every other page of the mag.
Bill G is offline
donjiskra
05-23-2009 12:32 AM
donjiskra
Seaplanes E-Powered
07-15-2008 02:57 PM
donjiskra
07-13-2008 09:10 PM
Papaw14
03-28-2007 08:41 PM
BeaverBob
07-21-2006 02:45 PM
Quick Reply: PBY conversion finished
Page generated in 0.07691 seconds with 21 queries
