novice needs help with a Turnigy 3530 1100 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-31-2011, 11:56 PM
postie
postie
Wink novice needs help with a Turnigy 3530 1100
hi...this is my problem...how to reverse the shaft on a C3530-1100 to fly in a multiplex fun cub???
when holding the motor the lettering in right side up and shaft is coming out of top of the motor .... I want it out the bottom
How do I decide which wire colours line up on the ECS???
yes I am a novice .... sure hope some will have the time to help me
postie
postie is offline
Old 09-01-2011, 05:07 AM
www.innov8tivedesigns.com
-> howto videos
-> exchanging a shaft
Old 09-01-2011, 05:26 AM
cyclingsarge
cyclingsarge's Avatar
I have a fun cub and I am trying to figure what why u need to do that? How about a picture for clarity.
cyclingsarge is offline
Old 09-01-2011, 06:51 AM
Also puzzled why you would need to do that unless the motor was incorrectly assembled by the factory (unlikely)
Forget the writing, that's just a sticker which could be stuck on either way.. The end of the motor that the wires go into is the fixed end. The motor shaft should normally stick out of that same end.
Like in the photo here (ignore writing, look at the wires): http://www.hobbyking.com/hobbyking/s...AXi_2808_.html
If you want to mount the prop on the opposite end to where the shaft sticks out then the motor comes with a prop adapter that bolts to the rotating end of the motor... The shaft would then just stick through a hole in the firewall/mount.
As for the wires.. just connect them any way you like.. If the motor runs backward swap over any two and direction will be reversed.
05-28-2020 09:50 PM
steinar
17
09-23-2011 06:21 PM
mcav8tr
08-19-2011 04:36 PM
pl365322
12
07-04-2011 07:41 PM
terrynshed
12-28-2010 08:46 AM
Quick Reply: novice needs help with a Turnigy 3530 1100
Page generated in 0.10036 seconds with 15 queries
