Help ... Hobby King / Art Tech Sound module plugs
Old 02-08-2016, 06:12 PM
Default Help ... Hobby King / Art Tech Sound module plugs
Can anyone help me identify the plugs used to connect to the Hobby King . Art Tech AT6 Sound module ?
I have a module but guy lost the cables for it. If anyone can identify the right plugs for it ... eternally grateful.
Old 02-09-2016, 10:54 AM
Decided in the end to hard wire leads direct to the module ..... Once I figured out polarity ... and that the Rx to module lead has RED where Signal should be ... it was easy. The socket plastic surrounds pull of easily leaving the bare pins ready to carefully solder the wires to direct.
The heat shrink was a difficult one and to be honest is crap ! So I think once tested .. I will cut away the heat shrink and Hot Glue around the pins to give support and insulate.
Standard servo wire used. I have a kit of wire and plugs with proper crimper ... so I knock out leads anytime I want.
Old 02-09-2016, 04:05 PM
Now here's one for the boys ...
The unit is supplied with 8 Ohm 15W speaker ... looks about a 2.5" or similar.
I gave a test of my module above with two 3W 8 Ohm speakers in parallel and in series ... no difference in sound level to a single either way .. I realise that the 3W is restrictive ...
I have four 15W 2.5" 8 ohm speakers coming and want to place all in the big lanc. Which way is best do you think ? Parallel two speakers to each module (I will have two modules in the Lanc) ... or in series for each module ?
Old 02-10-2016, 08:07 PM
Past President of PSSF
Not sure, but the plugs look like the same one as on my JR, TX main battery leads.
The power rating on a speaker is how much power it can handle before the speaker coil can not cool itself properly. If you feed a 2 watt signal to a 3w speaker or to a 15w speaker the volume should be similar if the two speakers are similar in efficiency and designed frequency range.
I think wiring the speakers in series might be safer for the amp. Should keep the current down in the final circuit.
I don't know the power output of the Turnigy sound system, but there are some small but powerful amps that could be added to give you plane shaking volume.
Wildflyer is offline
Old 02-10-2016, 09:02 PM
The power out is a lot more than my 3W speakers I know that.
I've now hard-wired the module so plugs no longer needed.
The other unit coming from HK will of course have the plugs ... but no problem.
I'm interested to see the difference in volume of my setup vs the original speaker etc.
02-05-2016 01:55 PM
frenchstan
Pusher Park Jets
01-30-2012 05:11 AM
hangingon
Company Discussions
43
01-25-2012 03:44 AM
tallflyer
Company Discussions
04-12-2011 02:10 AM
Quick Reply: Help ... Hobby King / Art Tech Sound module plugs
Page generated in 0.11874 seconds with 12 queries
