White Foam and Paper Wings? Poly?
Old 05-07-2008, 05:05 AM
Epowerreg
Real Flying
Epowerreg's Avatar
Default White Foam and Paper Wings? Poly?
I'm a newbie and covering white foam the (whole wing) wrapped with thin paper should I use polycrylic or polyurethane. Can I put the wings in the beds while this dries? I would like to be able to do that. Low temp film can/will go over this when done. Im making several for other people to build themselves.
Epowerreg is offline
Old 05-07-2008, 06:50 PM
TLyttle
TLyttle's Avatar
If you are covering with film, why use the polyurethane or polycrylic? I don't see the need for it...
TLyttle is offline
Old 05-07-2008, 07:13 PM
Kosh
Kosh's Avatar
I have agree, If your planning on covering the wing with film all your really doing is adding time and extra weight to the build. The iron on film adds the extra strength needed for this.
Kosh is offline
Old 05-08-2008, 01:06 AM
Epowerreg
Real Flying
Epowerreg's Avatar
Default Let me rephrase that
What I mean is what is better for applying the paper to the foam wing polycrylic or polyureathane. Will either one make white paper look like white film? Tips, Links and hints appreciated.
Keith
Old 05-08-2008, 01:15 AM
pd1
Still Learning
pd1's Avatar
If you're covering the wing with paper, then use the water based polycrylic.
Regular poly urethane might attack the foam.
If you want a smoother finish, you can use some pre mixed Spackle to fill the bumps and dents.
You'll have to test the paper and polycrylic to see what color you end up with, white sometimes gets a little transparent.
While the WBPU is drying, I wouldn't recommend it coming in contact with anything you don't want stuck to the wing.
There are a few theads on how to do the finish.
http://www.wattflyer.com/forums/showthread.php?t=14117
Covering and Finishing, Information
http://www.rc-airplane-advisor.com/h...-covering.html (X)
http://web.archive.org/web/200202060.../covering.html
http://pldaniels.com/flying/balsa/fi...yurethane.html (X) Water-Based Polyurathane (WBP) Over Fiberglass Cloth
http://www.coverite.com/accys/covr2700.html (Temperature Settings For Covering, popular Brands)
http://winshiprc.tripod.com/painting_techniques.htm
http://www.wattflyer.com/forums/showthread.php?t=23638 (Lettering, Numbers From Iron-On Material)
http://www.wattflyer.com/forums/showthread.php?t=20546 (Silk over Balsa, Thanks, Paul!)
http://www.wattflyer.com/forums/show...t=23572&page=2 (Japanese Tissue over Balsa, "")
http://www.wattflyer.com/forums/showthread.php?t=22327 (Silk With Polycryllic over Foam, "")
http://www.wattflyer.com/forums/showthread.php?t=21972 (Patching Film Coverings, "")
http://www.smoothair.rchomepage.com/...ithSolite1.htm
http://www.wattflyer.com/forums/showthread.php?t=10443 (Weights of Covering Materials)
http://www.modelflight.com/chemical.html
http://www.hobby-lobby.com/oracover.htm
http://www.antiquemodeler.org/www.an...omparisons.htm
Paul
pd1 is offline
bajinuk
Foamies
47
06-14-2011 06:32 PM
Water Boy
Foamies
09-08-2007 05:05 PM
Balsa_Butcher
Foamies
08-27-2007 06:10 PM
RCSkyFlyer
08-02-2007 05:26 AM
CitaFly
02-11-2007 03:38 PM
Quick Reply: White Foam and Paper Wings? Poly?
Page generated in 0.06892 seconds with 13 queries
