Building Blades
Old 03-01-2007, 01:32 AM
dCapo
Default Building Blades
Are there any links I can go to help on building your own blades for a CP? I am 7 -10 shipping days from a HS, it's not that I am that cheap:-). Other than airfoil and balance they seem pretty simple.
dCapo is offline
Old 03-01-2007, 01:48 AM
Sparky Paul
Sparky Paul's Avatar
I do it this way...
Make the mold using a broken blade for the shape out of Bondo, with 100 grit sandpaper fitted to the pattern blade before the Bondo.
Using a blank made with the proper chord and thickness, sand to shape.
Finish to suit.. I've used them bare, Monokoted, and covered with tape.
Balancing.. the fixture can be fancy or simple.
ID:	25367   Click image for larger version
ID:	25368   Click image for larger version
ID:	25369   Click image for larger version
ID:	25370   Click image for larger version
Sparky Paul is offline
Old 03-01-2007, 01:55 AM
dCapo
awsome. Thanks. I am new to helis but I love to build. Good thing too:-0
dCapo is offline
Old 03-01-2007, 04:47 PM
Lawn Dart
Crater Meistro
I make my own blades too. I've posted how to make it a while back, here's the link:
How to make your own blades
It's time-consuming, but worth it once you get the hang of it... You can experiment with different widths and lengths, wood types, etc. until you've found the perfect combination that works for you.
Have fun, and be careful! Getting hit by fragmented wood that's harder than balsa hurts like heck when a set of homemade blades bites it during a crash.
Lawn Dart is offline
Old 03-07-2007, 03:52 AM
rsking45
Would using monocote help from peices of splinterd wood flying all over when the blades strike ? Would heat shrink work the same?
By the way new to the site a heli.Thanks for the info on building blade and the info here.
Rich
rsking45 is offline
DanVanAcker
Beginners - Helis
67
02-19-2008 07:03 AM
Sky Sharkster
07-09-2007 02:25 AM
rockro
02-05-2007 05:15 PM
jcblough
05-20-2006 05:50 PM
Flytoolow
Support & Suggestions
02-02-2006 05:24 AM
Quick Reply: Building Blades
Page generated in 0.12563 seconds with 19 queries
