F4 phantom will not move - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-19-2017, 05:49 PM
Rcplanes13
Default F4 phantom will not move
I have the Nitroplanes F4 Phantom ARF for some time now. I relize that it is made for experts, but i chose to do it anyway. After working on it for a while and gaining new information, i put everything together, covered every place air can get in, and it will not move, even if i have the throttle all the way up. It just sits there and can't even move, i tried it on different and more smoother grounds, but nothing. I have contacted other people on this site and many more, which has helped me and the most related to this problem is the thrust situation, it weighs about 10lbs and the thrust is half which should make it work, but doesn't. I really need help/ideas!!!
Rcplanes13 is offline
Old 07-19-2017, 06:10 PM
formontoya
could the motor be spinning backward? what do you feel when you "have the throttle all the way up"? Not knowing what you have I would say just swap any 2 wires on the motor and see what happens...
formontoya is offline
Old 07-19-2017, 06:15 PM
Questions :
What battery do you have ?
What battery is recc'd ?
Is it on free-running wheels ?
Have you calibrated the throttle ?
Are you sure there are no obstructions IN and OUT of thrust / air passages ?
Old 07-19-2017, 07:19 PM
Rcplanes13
Here is the equipment
Motor:
http://m.ebay.com/itm/2Pack-70mm-Duc...%257Ciid%253A8
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 07-19-2017, 07:22 PM
Rcplanes13
Formontoya, they are both spinning in the correct direction
Old 07-19-2017, 07:25 PM
Rcplanes13
Nigel, i am sure there are no obstuctions in the way, i am just using the transmitter the same way as i pulled it out of the box
Old 07-19-2017, 08:13 PM
Have you calibrated the throttles ?
It is common for ESC's to not give full till calibrated to the throttle signal from the Tx.
Old 07-19-2017, 08:26 PM
Rcplanes13
I have tried to calibrate it before, but wasn't quite sure if i got it correct
Old 07-19-2017, 08:34 PM
Stay Quiet
Stay Quiet's Avatar
I've been looking at some of the OPs other posts on the forum.
Let's just say that the RC Gods are probably doing him a favor right now.
He has never flown before. His batteries are old and not up to snuff for an EDF. If he ever does get this ship airborne, it's not going to end well.
Stay Quiet is offline
Old 07-19-2017, 10:10 PM
Rodneh
What do you mean "covered every place air can get in"? You have to NOT obstruct the inlet area.
Rodneh is offline
Old 07-19-2017, 11:53 PM
Looks as if the advise previously given in other like posts 'has gone in one ear and out the other".......evidently compounded by the exit ear being against a wall and reverberating back into the skull........can't say we didn't try to be helpful.......
Old 07-20-2017, 06:44 AM
I do remember the previous thread ....
Just a comment - this is Wattflyer, we don't do snarky style remarks here. We may poke each other a bit at times, but we keep it 'nice'.
Guy needs help.
Old 07-20-2017, 06:50 AM
Rcplanes13 ...... to be honest - already we start to see that it may be a good idea to shelve this F4 for a while and get a trainer to learn on. This F4 will be a handful for any new / intermediate flyer.
Its also a good idea to Google / read up on regular things like Calibrating ESC to throttle etc. Those sort ofthings apply to all electric models.
Looking back over the photos ....
Do you have one or two ESC's ? Your photo only shows one. Brushless motors require separate ESC for each ....
Old 07-20-2017, 01:10 PM
Agree with all advise given. Nothing to add other than request you post a video of the f4 running at WOT on pavement or street.
Would a single brushless esc even work 2 motors at all. I know it takes 2 and just wondered having never tried wiring 2 motors to one esc. I also agree 100% regarding our responses to one another. Best advice of all.
Old 07-20-2017, 01:21 PM
Stay Quiet
Stay Quiet's Avatar
Guy needs help.
I apologize if my remark came off as "snarky". It wasn't intended to be.
Does the OP need help? Yes, obviously. Has he been given good, solid advice and suggestions in previous posts? I believe so. Have the advice and suggestions been heeded? Evidently not.
Assisting him with technical issues to get this dual EDF jet into the air isn't really "helping" at this point. We all know how that flight will most likely end.
I'm all for helping a newbie out, and helping where I can, even if the question(s) being asked have been asked countless times before by other newbies. It's when questions are asked, answered, the answers ignored, and the questions asked again, that I begin to feel that I may be wasting my time assisting.
Old 07-20-2017, 01:24 PM
My comment wasn't actually aimed at you !!
I agree.
Old 07-20-2017, 01:27 PM
I have witnessed one ESC running two BL motors - but it was pure luck IK reckon .. the synch pulses would not normally match ... etc.
I've looked again and I missed the second ESC sitting deep in on the left ...
Now I wonder if only ONE ESC is actually firing up ... maybe he hasn't plugged in the two ESC's correctly ?
I must admit that the Radio with this F4 is not the best ... based on the FlySky CT6B ...
Old 07-20-2017, 03:07 PM
Is this the LX twin 70mm ? Must have bought it sans motors and esc's ? Kit?
The 3000kv motors should be fine on 4S. Twin 60 amp esc's should be fine depending on blade count. Like a lot of edf's there's usually a cheater hole covered by a grate. It's there for a reason. Those twin fans need air. FSA .
Timing on the esc's? How many poles are the motors ? Usually set timing to low setting on these edf's . Not saying that's causing her not to move. The lipo? Looked like 4S but what's the C rating? Anything under 30-35C is unacceptable in the edf world . These 3000kv motors need a high flow rate of goo ! In fact, I'd start there. What lipo is that btw?
I've had the 64mm F-4. A handful to say the least. The full scale Phantom was nicknamed " the brick" and all the replica models follow suit for the most part. This is absolutely not a first plane nor a second or even a third.
Why go through all of this preparation, spend all of this money for what will be a 20 second bad experience? Why set yourself up for failure? Like Nigel said, shelve it for now. Save this nice Naval fighter/ bomber for later.
Else you're guaranteed to leave the Hobby saying " It just wasn't for me"
Get a trainer and a sim.
Old 07-20-2017, 06:42 PM
P .... >
The CT6B is not a good radio for the F4 because a) its fast, b) it needs RANGE due to it will cover a large flight area ...
The CT6B is fine for a slow trainer though ...
The two threads have different base to work from ..... ones a Hot EDF - other is a slow docile trainer.
_sOnGoKu_
Company Discussions
12-15-2016 02:00 PM
_sOnGoKu_
New Product Announcements
11-09-2016 01:07 AM
Bobdaeronort
Pusher Park Jets
17
07-21-2015 05:02 AM
BullDog2012
Electric Ducted Fan Jets
20
09-12-2013 07:14 PM
propduster8
12-13-2012 01:42 PM
Quick Reply: F4 phantom will not move
Page generated in 0.09987 seconds with 19 queries
