lost plane finder,very loud!! - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
Old 12-10-2013, 04:31 PM
edray999
Eric R
Default Turnigy switch
I hunted for the Turnigy switch - Hobby King:
http://www.hobbyking.com/hobbyking/s...rnigy%20switch
PRODUCT ID: LUM-ONF
edray999 is offline
Old 12-11-2013, 07:31 PM
c.sitas
well yes maybe. I made mine from an article on flitetest forum. It used radio shack parts.I mentioned before , this thing triggers from a lost signal.So when your watching your pride and soul heading down with no more chance of saving it , just turn off the transmitter. It'll start right away.I didn't use the planes battery because of the high possibility of battery damage.I tried my best to make the unit bullet proof. It could be ejected and it's still gonna beep. I've used it a couple of times. So far it's great.
c.sitas is offline
Old 12-11-2013, 09:10 PM
I wonder if this would work with the microprocessor controlled receivers we use now days with 2.4 Ghz and similar. Turning off the transmitter, the receiver still sends servo signals to the servos. And, the alarm would have nothing to respond to.
Old 12-12-2013, 08:45 PM
c.sitas
Kyle; I use a Flysky ct6b,a computor radio. The way this works is with a relay that's normally closed. The signal opens the relay and stops the beep.When I turn the trans. off, it loses the signal ,relay closes and here comes the beep.Like I've mentioned before 2to 3hundred feet you hear it.I used one with an up and down wail like an ambulance.
c.sitas is offline
Old 12-27-2013, 04:33 AM
c.sitas
Might be similar to HK unit but,at least 5times loader. only draw back I can see is the extra weight.On the size models I fly ,I don't even know they are aboard.I've made one for each plane I fly. I feel much more confident flying ,knowing I'll at have a good start at recovery of my craft. I still know how to dump one once in a while.
c.sitas is offline
stinkweed007
04-16-2009 11:51 AM
donjiskra
05-24-2008 05:49 PM
Larry G
08-06-2007 04:38 PM
RSS Feed
RCU RSS Feed
08-27-2006 02:54 PM
Quick Reply: lost plane finder,very loud!!
Page generated in 0.08117 seconds with 12 queries
